2015 Prius v Hybrid System Malfunction indication
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Carl Mims, Sep 5, 2022.
  1. Carl Mims
    Carl Mims Junior Member
    Bozeman, MT
    2015 Prius v wagon
    The car was idled for about 5 minutes to cool down the cabin on a hot 95-degree day. We then drove about 3 miles on a secondary road and about 6 miles on the interstate at 70+ mph.. The Hybrid Malfunction indication came on. We immediately slowed down and stopped on the shoulder of the interstate, Shut down the car, and raised the hood to make sure of coolant, any leaks, oil.. etc. Everything was dry and normal. Started back up and drove about 5 miles to the nearest exit with the HSM on, pulled into a gas station and parked under the shade of the awning. Let it cool for about 15 min and restarted with the same HSM indication. So turned the car off and disconnected the 12v battery, reconnected after about 1 min, put it all back together and started again. No error messages at all so drove home about 45 miles on the interstate and have used it for about 30 miles around town driving without any problems.
    Was it just a hot day and the mistake of idling for creature comfort?
    What is my next step? Hoping to avoid the dealer since the last repair was to replace the radiator about 2 years ago at a cost of over $2k. Car has about 150K miles on it
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,125
    6,980
    Texas Hill Country
    The mistake was clearing the codes with the 12v disconnect before seeing what the code was. 90% it was a hybrid overheating code, most likely the hydrid inverter/transaxle circuit fed by the inverter water pump. The hybrid battery temp is much less likely but possible. Sometimes the standard "observe the reservoir" for fluid movement could hide a worn inverter pump impeller. Obviously you look at the reservoir level and verify fluid movement. But these electric water pumps don't leak or completely fail most of the time. Their impeller becomes degraded reducing flow.
    Might get a scanner that would read these codes. Often Car Scanner or Dr. Prius is adequate with a bluetooth obd2 scanner. Have it in the car ready to go with the apps installed and tested. At that point you either duplicate the conditions that caused it, wait for a recurrence or fire the parts cannon with oem only parts while being fully aware of counterfeits on ebay and amazon,
    52,877
    have you cleaned the egr circuit?
  4. John Snider
    John Snider New Member
    28705 Ryan Creek Rd, Willits, CA
    I too, am having problems with my 2012 V, with 245k miles. HMS light came back on along with traction control light. Gas engine will not start, can accelerate to 25 mph+. Two codes stored on reader: P0401 and P0335. One possible cause on both: Dead (Weak) battery. Had 12V battery load tested today, 300 amp test and performed fine. This is the original battery (to the best of my knowledge - I am the 2nd owner, purchasing car in 2015 with 67k miles on odometer). Yesterday, used OBII tester for above codes, cleared codes at end.
  5. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    A seven year old 12V auxiliary battery is beyond end of life, no matter the test result. Just saying.
  6. ChapmanF
    19,041
    Both aux batteries I've replaced in Prii that I've owned were a hair past the ten-year mark.
    CR94 and Air_Boss like this.
  7. Air_Boss
    4,259
    1,197
    New Yawk
    Living on borrowed time! Twice!
  8. CR94
    CR94 Senior Member
    2,833
    1,244
    Northwestern S.C.
    And mine just passed 7½ years. It leads a very easy life, compared to a battery that must crank an engine and endure under-hood temperatures.
