2015 Prius V jacking point
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Andrew Brousseau, Mar 7, 2021.
  1. Andrew Brousseau
    Andrew Brousseau Junior Member
    Cape Ann, Massachusetts
    2015 Prius v wagon
    Hello all, I just lost my post after being redirected to upload images, so I will keep it brief. I understand the jacking points with the scissor lifts. I used to only use them on my Subarus until the jack pushed through my frame. BTW Why doesn't this Prius leak oil?
    I'd like to use a floor jack on my 2015 Prius V. Is the pictured location below suitable? It is on the front cross member where the engine/transmission have a connection to. I have seen diagrams from other Prius models showing a jacking point on a different cross member that is in between the wheels. I can't reach there with a floor jack though. So... Is this front cross member a suitable jack point?
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,992
    Texas Hill Country
  3. Andrew Brousseau
    2015 Prius v wagon
    Thanks, so that picture appears to show the location I am referring too. I assume that is for my model.
  4. Air_Boss
    Air_Boss Senior Member
    4,263
    1,197
    New Yawk
    The rear jacking post is clear, but I remain uncertain of that front jack point in the jacking diagram in the v owners manual, so I ramp the car to do work underneath the front.
  5. rjparker
    11,152
    6,992
    Texas Hill Country
    Yes the front is what you pictured.
  6. Mendel Leisk
    42,386
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    With the proper adapters, the $27.88 two tom Hypertough Walmart hydraulic two ton trolley jack is ideal for jacking both the front and real jacking the front and rear lift points of all Gene 3 Prius models including the "v."
    Hyper Tough 2 Ton Trolley Jack Red/Black - T82011W - Walmart.com - Walmart.com
    A simple aluminum rings allows the jack to "lock-on" the front jacking point without slipping off. This allows the jack to roll to compensate. partially jacked up.JPG The jack will not lift high enough to get both the rear wheels off the ground at the rear jacking point. The can be remedied by using the custom 2-1/2 inch rise that we developed especially for this purpose. extended height on jack.JPG
    Wolverine88 likes this.
  8. Air_Boss
    4,263
    1,197
    New Yawk
    I use a high density urethane disc on a 14" lift quick jack, and place it on a piece of 3/4 Inch plywood to get the lift required out back (and protect my techo-block driveway).
    #8 Air_Boss, Mar 9, 2021
    Georgina Rudkus likes this.
  9. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Air_Boss likes this.
  10. Air_Boss
    4,263
    1,197
    New Yawk
    I don't use the pinch weld jacking points. Only the chassis jack points.
    I don't trust loading the pinch welds not to cause yielding in the sills.
  11. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    If done with the correct adapter, no damage will happen to the sills. Unfortunately, most adapters are too shallow and supports the jacking point only by the vertical "knife edge." Correctly done, it is securely supported at three linear places.
  12. Air_Boss
    4,263
    1,197
    New Yawk
    Right, "unfortunately, most adapters are too shallow", which is why I stick to the chassis lift points, and ask the inspection station lift guys to be extra careful when lifting to do their system and check brakes, etc..
    Georgina Rudkus and Mendel Leisk like this.
  13. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    I milled mine out with the correct deep slot. The soft urethane doesn't damage the expensive plastic rocker covers.
    Luckily, we don't have state inspections in South Carolina.
    I am a native New Yawker.
    #13 Georgina Rudkus, Mar 9, 2021
  14. Mendel Leisk
    42,386
    I'm never using the scissor jack points (or anywhere in the vicinity) for jacking, just safety stand placement, after raising either the front or rear. A 3 ton jack with decent lift, and a block of 2x4 on the flat plus a hockey puck, for the rear, I've got no problems.
    Not sure how sim the v is, but these are the safety stand points I use on my gen 3 (red blobs):
  15. Air_Boss
    4,263
    1,197
    New Yawk
    I've seen some of the wrecks in SC. They're not all offshore.
  16. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Seen a lot of rusted hulks in New Yawk and more than in South Carolina.:)
  17. Air_Boss
    4,263
    1,197
    New Yawk
    Yes, but they are inspected rusted hulks...
  18. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    I know, because I am a native New Yawker born on the upper West side.;)
  19. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    For the Walmart $27.88 plus tax jack, I found that, if you remove the center cup by pulling the little spring loaded "safety pin" from the center of the swiveling saddle, the "cup" that holds it perfectly fits the front jacking point "nub" and keeps it securely locked on place. As the front end rises, the wheel of the jack turn, instead of slipping off the jack.
    64f4928b-ab7a-404e-baae-999a68ac8340_1.36ca567cfea66f2883818f9b225a8b28.jpeg You will, however still need the riser adapter to raise the rear jacking point high enough to have both rear wheels off the ground.
  20. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Ever since I got my 2012 Prius v, I have searched and wide for those elusive Toyota service manual jacking blocks.
    We finally mode our own by milling out aftermarket polyurethane jacking blocks made with slots that came too shallow.
    This is the diagram from the Toyota service manual specifying those elusive blocks. blocks used with lift.jpg jacking blocks.jpg
