2015 prius v storage
Discussion in 'Prius v Main Forum' started by gone2green, Apr 30, 2018.
  1. gone2green
    gone2green grumpier than the grumpiest old man you know ;)
    117
    17
    Mesa AZ
    2015 Prius v wagon
    I will be leaving for 3 months, is there anything I should do to store it.? it will be outside under a carport
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Ideally?
    Get the tires off the ground so they don't develop flat spots.
    Do an oil change just before so no water in oil.
    store the 12 volt battery on a charge maintainer for AGM using clips, 'cigarette lighter' plug is nonfunctional when car is off.
    Have the HV battery mostly charged
    in practice?
    if you skip all that you may need a new 12 battery. yours is getting up there anyway.
    #2 JimboPalmer, Apr 30, 2018
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,755
    6,749
    Texas Hill Country
    I would put it on a 12v trickle charger attached directly to the 12v battery and inflate the tires to the maximum allowed on the sidewalls. Ideally having someone start and drive it every two weeks would be nice. Some people might put it up on jack stands to avoid flat spotting the tires. The trickle charger should be a three or four stage unit, not that old one in the garage.
  4. padroo
    padroo Senior Member
    2,763
    2,253
    At minimum disconnect the 12 V battery. It should hold for three months with no load.
  5. mikefocke
    4,054
    1,845
    Sanford, NC
    Park in Styrofoam blocks. Inflate tires. Oil change just before to reduce acids in gas. Park it after a longish high speed run of 20 miles. Disconnect battery (12v). Battery maintainer on battery. Put anti-rodent scents around and in car. Have a great trip.
  6. gone2green
    117
    17
    Mesa AZ
    2015 Prius v wagon
    Thanks everyone, I will put the battery on a maintainer charger, will have to leave it on the ground but will have fully aired up tires etc...
