2015 reset maintenance light prius v4
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by sean v4, Jan 25, 2016.
  1. sean v4
    sean v4 Junior Member
    Corona, CA
    2015 Prius v wagon
    Is there a way to reset the maintenance light warning for 2015 prius v4?
    I have tried press and hold km/mph and pressing power twice and no luck. and tried pressing the trip with the power twice and no luck..
    thanks,
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,013
    6,902
    Texas Hill Country
    It's in the manual but on a 2012:
    1. Place ODO readout on "Trip A"
    2. Power down
    3. Hold KM/M switch down as you press Power button twice (no brake)
    4. Keep holding KM/M while ODO readout goes from ------- to 000000
    Done
    #2 rjparker, Jan 25, 2016
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Step 1, leaving ODO on Trip A is the one that always "trips" me up.
    DogDaze likes this.
  4. nj124
    nj124 Junior Member
    2015 Prius v wagon
    I have a 2015 Prius v (lowercase v) Three . This model includes 4.2-in. TFT Multi-Information Display w/ selectable screens, which means the Trip button is a separate button on the steering wheel, not part of the 4 way circle switch.
    I still cannot reset the "maintenance required" message that covers the entire TFT (except for the bottom row showing the odometer or trip-meter). There is no "light", just the message. The procedure above is in my manual but does not work. Tried "Trip A" and all other starting indicators, no luck.
    Does anyone have another procedure for models with TFT?
  5. bisco
    52,787
    is it worth disconnecting the 12v for a minute?
  6. BrakALack
    BrakALack New Member
    Bay Area, CA
    2015 Prius v wagon
    Just encountered this with my 2015 Prius v 3. The instruction manual is just plain wrong for the newer models—I went to YouTube for the proper fix, which involves no combo-pressing of trip buttons and power buttons and magic incantations.
    1. Turn the car on.
    2. In the heads-up display on the top of the dash, use the navigation pad on the steering wheel to navigate (left or right) to the gear icon, which is "Settings". Hit the center button to select.
    3. Navigate down to the "Maintenance System" menu item. Hit the center button to select.
    4. At the "Do you want to initialize?" prompt, select "Yes". Hit the center button to select.
    That should do it.
    mbenz likes this.
  7. belladorje
    belladorje New Member
    eugene
    #7 belladorje, Dec 2, 2019
  8. mbenz
    mbenz Junior Member
    Las Vegas
    2015 Prius v wagon
    Perfect!
