2015 Squeaking Noise After Routine Maintenance
Discussion in 'Gen 3 Prius Technical Discussion' started by 7akizzle, Oct 8, 2024.
  1. 7akizzle
    7akizzle Junior Member
    Oregon
    I got some work done on my 2015 Prius (130K) today, and now I’m getting like a squeaking loud noise intermittently between braking and slowing down/starting. Wasn’t there prior, but my rear breaks were 4mm when I came in . Any idea??
    Work that was done:
    Brake Flush
    Inverter Coolant
    Cooling System Flush
    Auto Transmission Hybrid Drain & Fill
    120k Service (Oil Change, Spark Plugs, etc)
    52,400
    any idea where the squeak is located?
  3. 7akizzle
    Oregon
    Yes, It’s happening in the front.
    52,400
    engine bay or suspension/wheels?
  5. ASRDogman
    ASRDogman Senior Member
    7,833
    3,990
    Perhaps they bent the brake disk shield and it's scrapping wheel...
    And it's probably just enough that you hear it when you are going slower.
  6. Mendel Leisk
    41,925
    Would this be engine and inverter coolant drain and fill? Just to clarify, not sure how it would be relevant.
