2015 Toyota Prius (JL Audio)
Discussion in 'Gen 3 Prius Audio and Electronics' started by MDGJR, Jul 6, 2021.
  1. MDGJR
    MDGJR Junior Member
    25
    San Diego, CA, Coronado Island
    2015 Toyota Prius
    JL Audio System
    Stock Head Unit
    Front fill: C3-650 separate components
    Rear fill: C3-650 separate components
    Sub: 12w3v3 (Custom Ported Box)
    Amplifiers: Front fill JD400/4
    Rear fill JD400/4
    Sub JD1000/1
    Signal processor: AudioControl Lc7i
  2. LincolnW
    LincolnW Junior Member
    Portland Oregon
    Very nice! Have you upgraded the power system at all? Are you using a secondary battery?
    I'm running about 700 watts RMS on the stock battery and I'm concerned about taxing it too much, and you are running more than me.
  3. MDGJR
    MDGJR Junior Member
    25
    Everything is stock at the moment. But I will need a better battery and a new alternator, at some point.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    which ones are you looking at? I’m in the process of finding one also.
  5. ASRDogman
    ASRDogman Senior Member
    8,036
    4,073
    Where is the alternator located on the Prius?
    Grit likes this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    heard it’s probably under to hood, that’s were the engine spins and belts to the alternator.
    ASRDogman likes this.
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,987
    6,889
    Texas Hill Country
    It is in a box you bought at Autozone for your Honda
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    so your playing music from which source and audio format?
  9. rjparker
    10,987
    6,889
    Texas Hill Country
    Instead of a high power alternator you need a second high amp hour battery and a quality fet battery isolator to handle the peaks of a custom audio system. Same recipe for a kw or better 12vdc inverter.
    #9 rjparker, Jul 15, 2021
    MDGJR likes this.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    we want alternator!!!
  11. MDGJR
    MDGJR Junior Member
    25
    My iPhone, MP3’s
    iPhone ?
  12. MDGJR
    MDGJR Junior Member
    25
    Thank you I will look into that ASAP. Appreciate it.
    iPhone ?
  13. MDGJR
    MDGJR Junior Member
    25
    You are a little bitch. Who hides behind there computer acting like a tuff guy. You are just a worthless bully. Stay off my threads and go somewhere you are appreciated. If you’d like to talk about this I would be happy to communicate with you one on one.
    iPhone ?
  14. rjparker
    10,987
    6,889
    Texas Hill Country
    Grit is our comic relief sometimes with stinging sarcasm that does not come through in print. We all try to make it to his signature Hall of Shame.
    MDGJR likes this.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    No way biatch! This little bitch wants to settle this here where no one owns anything, this public domain!!!
  16. ASRDogman
    8,036
    4,073
    I would never own a honda!
    So I guess my Prius will have to live without an alternator...:p
  17. ASRDogman
    8,036
    4,073
    Grown up. Everyone acts tough behind the keyboard, or a mask....
    If you can't handle the comments, block them, or don't read them.
    MDGJR likes this.
  18. MDGJR
    MDGJR Junior Member
    25
    So you think a Prius is a Honda……
    iPhone ?
  19. ASRDogman
    8,036
    4,073
    So you don't read the posts?
    I posted:
    rjparker posted:
  20. MDGJR
    MDGJR Junior Member
    25
    Blocking is such sweet sorrow. Thanks for the reminder. Bye grit!
