2015 V runs poorly after engine swap.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by scott Kampfer, Jul 5, 2025.
  1. scott Kampfer
    scott Kampfer New Member
    after swapping engines the car run's poorly. is the flywheel timed?
  2. 2015V-BadHG
    2015V-BadHG New Member
    24
    Portsmouth NH
    2015 Prius v wagon
    My first question is about the long block you swapped in.
    Where did you get it?
    Runs, idles poorly as its misfiring?
    Has no power?
    I'd pull plugs to see what they tell you.
    Put a old fashioned vacuum gauge on it to see how it fluctuates.
    Pete
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,762
    6,752
    Texas Hill Country
    Most of the time it's a disconnected pcv or vacuum hose or sensor. Some are hard to see.
    It is essential to accurately describe the issue when seeking free internet advice.
    Brian1954 likes this.
