2015 with 82k miles, first ATF change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sambojoho, Oct 24, 2023.
  1. sambojoho
    sambojoho Proud conservative
    92
    23
    Ohio
    I just drained and refilled the ATF. for the first time. It was not too bad looking, deep red but not black. It took 3.5qt to refill, and I did it by snaking some tubing down from the top and used a funnel to refill. I used Aisin WS.
    I had the front up on ramps, then jacked up the back and set it on jackstands. I put a level on the passenger door sill to determine how far to jack up the back. Worked great in my slightly sloped driveway. Biggest pain of the job was taking the trim panel off and on.
    just thought I would share.
    52,873
    well done!(y)
