2016. 150000 maintenance
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by char52les, Apr 25, 2026.
  1. char52les
    char52les Junior Member
    maineville ohio
    Just got my oil change for my 2016 Prius 150000 miles. Dealer says the following items are required at this mileage……
    Drain and fill engine coolant
    Drain and fill hybrid inverter
    Transmission fluid service
    Brake fluid service
    Replace spark plugs
    Are these required maintenance services at this mileage?
  2. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Engine and hybrid coolants should be drained and filled at 100k miles and every 50k miles thereafter.
    Changing the Transmission fluid (ATF) is a good idea. I suggest a first drain/refill at 30k miles and then at 90k miles and every 90k miles thereafter.
    Brake fluid does absorb water over time and there are test strips to check the water content.
    Irridium spark plugs are good for 120k miles so it is time.
    You might also consider replacing the PCV at this time.
    Your dealer is being reasonable as long as prices are OK
    JeffD
    #2 jdenenberg, Apr 26, 2026
  3. Mendel Leisk
    42,237
    The Toyota USA publication Warranty and Maintenance stops at 12 years or 120k miles, and is a clumsy, event-by-event format. I’ve transcribed it to table format, and extrapolated to 24 years or 240k miles, in attached.
    going through your list, comments in red, guesstimates in green:
    Drain and fill engine coolant $150
    Drain and fill hybrid inverter coolant $125
    Transmission fluid service presumably drain and fill $100
    Brake fluid service presumably replacement $150
    Replace spark plugs $200
    ^ have the plugs ever been changed? If not then yes, they’re overdue, should have been done by miles at 120k. Unless you’re CARB state, where it’s 150k.
    coolants are both due, by miles.
    transaxle and brake fluid are not mentioned by Toyota USA, but worthwhile
    #3 Mendel Leisk, Apr 26, 2026
