2016 2 Eco Misfiring
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by 2016eco2, May 3, 2026.
  1. 2016eco2
    2016eco2 New Member
    Philadelphia pa
    Two Eco
    Hi all, I have a 2016 with 250k. Today after Ive been driving for awhile it started missing on acceleration but theres no check engine light. Coolant is full, plugs look good. Seems to drive okay when its cold. I have a spare EGR system from my 2010 4th gen swap. I was just going to swap that over and see what happens. But i know these dont typically go bad on the 4th gen. Also it looks difficult do to the inverter being in the way. Any suggestions on what it could be? Thanks in advance.
  2. Mendel Leisk
    42,195
    How long have you had it?
  3. BiomedO1
    BiomedO1 Senior Member
    4,446
    2,341
    Left Coast
    A 2010 is a gen3; so unless you've got a very early 2016 - they're not compatible.
    Have you done ALL the required maintenance? ie. coolant changes, throttle body cleaning, air filter and intake tubes? Those are the two things I'd look at first
  4. Mendel Leisk
    42,195
    I “think” he’s got a gen 3 as well, swapped a gen 4 engine into it, and it had gen 4 EGR components which he retained?
  5. TinyTim
    TinyTim Active Member
    406
    240
    Seattle
    How about bad gas? When did you fill up your tank last? Has your car been missing for a prolonged period of time?
