2016 and 2017 Li-Ion Battery Longevity
Discussion in 'Gen 4 Prius Main Forum' started by ben_08, Oct 18, 2023.
  1. ben_08
    ben_08 Junior Member
    Greenville, SC
    2023 Prius
    Good afternoon All!
    Wanted to check in on those who have a 2016/2017 Prius with the Li-ion battery to see how well it has held up over the years. Still getting good MPGs after the 7-9 years on the battery? I know Toyota has been shifting to more Li-Ion on their hybrids and was wondering how these batteries are holding up compared to the tried and true NiMH battery. Look forward to hearing back!
  2. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    I recently sold my > 6 year old 2017 gen 4 Prius 4 with about 20k miles. It had a Li-Ion battery.
    There hadn't been any noticeable change in fuel consumption or battery charge/discharge behavior.
    I was wondering about how the battery would fare as the Li-Ion battery is not much more than 50% of the capacity of the NiMH one (750Wh vs ~1300Wh), so it will probably cycle more.
    kw
    ben_08 likes this.
  3. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    li-ion batteries last about five time longer than NIMH. NIMH isn't tried and true it's old and worn, (Toyota is very resistant to change and still hasn't fully invested in electric) but it is still used in the AWD Prius because it has better cold weather chemistry than Li-ion so.......
    ben_08 likes this.
  4. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2016 had the LiOn battery pack. It performed well until 2020 when a kamikaze deer totaled it. My 2020 AWDe has the older NiMh battery pack and it, as I expected, is still doing fine.
    I previously had a 2004 Prius with the NiMh battery pack. The pack lasted 195k miles (9 years) and only one module failed at that time with one bad cell. A commercially rebuilt battery was still operating well at 12 years and 280,000 miles.
    LiOn batteries can handle 200-500 full discharge/charge cycles before weakening to 80% capacity. In a Prius HSD, this should easily allow for a 10 year, 150k mile useful life, but the older NiMh batteries have proven that they perform well.
    If you really want to have a reliable, long-lived hybrid battery system, use LiFeSo4 batteries which can handle 10 times the discharge/charge cycles (2000-5000) than the LiOn batteries.
    JeffD
    ben_08 likes this.
  5. bisco
    52,754
    my 11 year old lion battery hasn't lost much capacity. i suspect the prime battery will outlast the car
    davecook89t and ben_08 like this.
  6. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It is interesting to note that EV makers are using LiFeSo4 Batteries as the lower cost (lower range) option. The battery packs with a higher KWH spec are LiOn.
    JeffD
  7. bisco
    52,754
    is that tesla?
  8. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes, but they're not alone. Toyota's EV plans for 2006 are similar.
    JeffD
  9. bisco
    52,754
    is it also because the chemistry qualifies for the tax credit?
  10. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The only mineral that is relevant is that LiFeSo4 batteries do not contain cobalt.
    JeffD
  11. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
  12. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
  13. Drakxyfly
    Drakxyfly Member
    119
    29
    Usa
    2021 Prius
    Sorry but again completely disagree. It's been widely published that Toyota has not fully invested in EVs, and 2027 is basically three years from now so that is not long term(especially since they just start real world tests of these solid state batteries). They are still spending money researching and developing hydrogen and alternative fuel sources, as well as spending the last three years developing a new type of automatic racing transmission the DAT for the new GR cars and racing applications. Maybe from a perspective of what type of battery cells they are using they have a similar plan, but overall Toyota is much more diversified than that for the future and hasn't really committed to one single strategy yet.
    cthorsman likes this.
  14. Mr.MPG
    Mr.MPG Member
    30
    50
    Southern California
    Four Touring
    Mine is 2016 Prius Four Touring bought March 2016, still getting 75MPG in ECO mode, been it that mode since day one. I have replaced 12V battery in 2020 and new set of tires this year. So far, no loss of mileage or anything hope my Hybrid pack it will last till 200K.
    Cheers.
    MrMPG
  15. kevinwhite
    333
    200
    Los Gatos Ca
    Surely you meant LiFePO4? (Phosphate not sulphate).
    kevin
  16. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You are correct.
    JeffD
  17. sylvaing
    sylvaing Senior Member
    1,215
    514
    My 2017 Prime still did 42 km per charge with my summer tires last summer. Winter tires at mild temperatures drops this to 36 km. Next week, I'm putting back my summer tires. I'll see if the range has remained 42 km from last year with these tires.
