2016 Camry Hybrid - Force Start ICE
Discussion in 'Toyota Hybrids and EVs' started by Morpheous, Oct 29, 2020.
  1. Morpheous
    Morpheous Junior Member
    Australia
    ----Australia----
    Hi all forum goers,
    I have a 201y Camry Hybrid and I am trying to diagnose a P0171 code. Sensors are finme and alternate sensors are showing the same code.
    I suspect possibly an air leak on the manifold or intake, but can't keep the engine ICE running enough to check. It keeps shutting off.
    Any tips and tricks to keep the car in ICE mode?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    What year is your Camry?
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Set HVAC temp to 30C/max, open windows or doors, floor accelerator pedal to start ICE (if needed). Many leaks are small hose/tubing related.
    GOOD LUCK!
    Trollbait likes this.
  4. Mendel Leisk
    42,345
    Put car in maintenance mode. @NutzAboutBolts video on engine coolant change shows the procedure, in a 3rd gen Prius. Might also work for you, or search for Camry maintenance mode.
    NutzAboutBolts and Trollbait like this.
  5. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Clean the MAP sensor. If code comes back again, replace MAP sensor.
  6. fotomoto
    5,639
    3,815
    So. Texas
    My Ozzie is a little rusty but I think that's what this says:
  7. Morpheous
    Australia
    ----Australia----
    Issue was a fuel pump not supplying sufficient fuel pressure.
    Having said that, maintenance mode is a useful one to know!
    Thankyou
  8. alanclarkeau
    7,045
    7,593
    Good news - what year is it - it didn't come out in your first post "... a 201y Camry Hybrid"
  9. mikefocke
    4,079
    1,862
    Sanford, NC
    Isn't there a recent fuel pump recall in the US affecting many models?
  10. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
    It is a 2016 as stated in the title.
    alanclarkeau likes this.
