2016 Chevy Volt To Have Lower EV Range, 30 Miles Or Less?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Sergiospl, Mar 6, 2013.
  1. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    I thought Nissan Leaf was $35,000 or $37,000 last year. 2012 Nissan Leaf Reviews and Ratings - The Car Connection
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Sergiospl likes this.
  3. Sergiospl
    3,938
    1,351
    28
    GM Considers Three-Cylinder Engine for Chevrolet Volt, Cadillac ELR | Edmunds.com
    • GM is eyeing a three-cylinder engine for the Chevrolet Volt and Cadillac ELR, industry sources tell Edmunds.
    • It's part of a major effort by the automaker to reduce the fuel consumption and weight of its vehicles by 2016.
    • GM says it's too early to talk about its three-cylinder-engine strategy.
    "A good rule of thumb is that a 10 percent reduction in curb weight will reduce fuel consumption by about 6.5 percent," Akerson said in a copy of the speech that was released by GM. "Our target is to reduce weight by up to 15 percent."
    austingreen likes this.
  4. austingreen
    austingreen Senior Member
    13,677
    4,214
    Austin, TX, USA
    Hey the most substantial part of that is the date for gen II should be in 2015 as a 2016 model. The 1 liter 3 cylinder was the original volt plan. I would definitely expect a more efficient engine in the gen II, but they were floating other options as well. A 3-cylinder may hurt when it comes to nvh, which may hurt sales even if it increase mpg in cs mode. If they only increase electrical efficiency 8.5% that is likely from changes they get to the magic 40 miles with a 16kwh pack.
  5. Sergiospl
    3,938
    1,351
    28
    A more efficient engine, weight loss with some carbon fiber, aluminum, lightweight steel, and other materials should make Gen II even more interesting.
  6. austingreen
    13,677
    4,214
    Austin, TX, USA
    I think carbon fiber costs too much, but who knows, in 2015
    GM Is Bringing Carbon Fiber To The Masses | Autopia | Wired.com
    The volt probably can lose that 15% by a lighter battery and engine, different design and more use of high strength lightweight steel. Its 3781, which is not light now, 3200 lbs will let them use lighter weight suspension and uni-bodies. If they can make it a little more aerodynamic at the same time there can be a big boost in gasoline fuel economy.
  7. Sergiospl
    3,938
    1,351
    28
    Autoline daily; how automakers are getting ready to use carbon fiber by 2016.
    OEMs Lock Up Carbon Fiber Supply Chain - Episode 1093 - YouTube
