2016 Hybrid System Malfunction, Failed Inverter? 116K miles
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Tijerina79, Mar 23, 2022.
  1. Tijerina79
    Tijerina79 New Member
    Riverside, California
    Three Touring
    I have a Gen4 2016 Prius with 116K miles that just experienced a Hybrid system malfunction. After the error came on the dash, I kept driving a few more miles but then the 12volt battery voltage became too low and the car refused to drive any further. I had it towed to the dealer and they spent 2 days (and a $500 diagnosis fee) trying to diagnose the problem, then they called me and said the inverter failed and it would cost almost $4,600 to install a new inverter. Could their diagnosis be wrong? I know Gen3 Prius had issues with the inverters but I thought they fixed it for the newer models. Has anyone else experienced this issue? What would cause a 2016 inverter to fail at only 115K miles?
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Anything can fail, but the usual cause of an inverter failure is connecting a 12v battery backwards when jumping the Pius or replacing the battery.
    Tijerina79 likes this.
    52,862
    a reasonable mech can throw in a salvage inverter for a few hundred dollars.
    but first, ask for the codes from the dealer, and post them here. this is a very unusual failure.
  4. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Thats horrible news. Like Bisco said maybe call around to a few other Prius repair shops or see if they can install a used inverter. The only thought I could think of is that there was an issue with the wires going into the inverter and there was a TSB for that where they taped them up to protect them from rubbing and failing.
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    If you live in California or other carb states it should be covered by the emission warrantee. Also I thought Toyota did 150,000 or 10 year warranty on hybrid system. I would check around.
    robsnyder20 and Merkey like this.
  6. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
    If the car was bought in Calf, check out the Calf/CARB-States warranty:
    California Emission Control Warranty
    MANUFACTURER’S
    WARRANTY COVERAGE
    Selected states 1
    For 15 years or 150,000 miles, whichever
    occurs first: 2
    • If your vehicle fails a smog-check test,
    all necessary repairs and adjustments
    will be made by Toyota to ensure that
    your vehicle passes the test. This is
    your Emission Control System
    PERFORMANCE WARRANTY.
    • Subject to the specific terms
    pertaining to maintenance described
    on the following pages, if any
    emissions-related part is defective, the
    part will be repaired or replaced by
    Toyota. This is your Emission Control
    System DEFECT WARRANTY.
    Starting on page #24.
    https://assets.sia.toyota.com/publications/en/omms-s/T-MMS-Prius/pdf/2016PriusWSG.pdf
    1. Applies to California, Connecticut, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Rhode
    Island and Vermont vehicles equipped with a California Certified Emission Control System.
    2. Warranty coverage for the hybrid battery is 10 years or 150,000 miles, whichever occurs first.
    Note, the latest warranty info has things defined more clearly:
    Look at Page 27
    https://assets.sia.toyota.com/publications/en/omms-s/T-MMS-22PriusPHV/pdf/T-MMS-22PriusPHV.pdf
    CALIFORNIA EMISSION CONTROL WARRANTY
    PARTS LIST:
    LONG-TERM EMISSION
    DEFECT WARRANTY
    The parts listed here are covered for seven
    years or 70,000 miles from the vehicle’s
    in-service date,
    Air Induction/Exhaust System
    • Intake manifold
    • Throttle body
    Catalyst System
    • Exhaust front pipe
    (including catalytic converter)
    • Exhaust manifold
    EGR System
    • EGR cooler gasket
    • EGR pipe
    • EGR valve
    Evaporative Control System
    • Charcoal canister
    • Fuel sub tank
    • Fuel tank
    • Fuel tank filler pipe
    Fuel Control System
    • Engine control computer
    (engine control module)
    • Fuel delivery pipe
    • Fuel pump
    Hybrid System
    • Battery control module
    (battery voltage sensor)†
    • Brake master cylinder for HV
    • Electric vehicle charger
    • Hybrid battery†
    • Hybrid battery heater
    • Hybrid battery heater relay
    • Hybrid battery junction block
    • Hybrid control module†
    • Inverter with converter†
    • Oil pump with motor
    • Transaxle (including motor
    and generator)
    • Water pump with motor
    Other Parts Used in
    Systems Listed
    • Cooling fan motor with controller
    † Covered under the Hybrid System Warranty for eight years or 100,000 miles, whichever occurs first, with the exception of
    the hybrid battery covered for ten years or 150,000 miles, whichever occurs first.
    You may also want to give the CARB number a call.
    If you have any questions regarding your
    warranty rights and responsibilities, you
    should contact the Toyota Customer
    Experience Center at (800) 331-4331
    or
    the
    California Air Resources Board, Mobile
    Source Control Division, at 9528 Telstar
    Avenue, Suite 4, El Monte, CA 91731,
    (800) 242-4450.
    robsnyder20 and 2010moneypit? like this.
  7. Cybr
    Cybr New Member
    united states
    I have a 2017 Prius Prime and received P0A1B94 today. I don't know what it means, but I cleared it, and I'm praying it doesn't come back. Any idea what it could be or what I should look out for? Prior to this I was dealing with a low 12V battery message and ended up fixing a brake booster that was leaking brake fluid.
  8. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Or maybe overheating? How's the inverter coolant or coolant pump doing?
  9. bisco
    52,862
    that post is 2 years old
    BiomedO1 likes this.
  10. bisco
    52,862
    none at all. here is what dr. google says:
    RM1000000018HG8.xml
    Brian1954 likes this.
