2016 Prius 20% improvement in MPG?
Discussion in 'Gen 4 Prius Main Forum' started by iplug, Sep 10, 2015.
  1. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    So with two whiffs on two car shows. Anyone want to guess which car show is now most likely to see specs released?
  2. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    Probably Tokyo end of next month:
    2015 Tokyo Motor Show Press Days - 6 weeks!
    October 28 (Wed)
    October 29 (Thu)
  3. Mendel Leisk
    42,285
    I'd heard that, guess you're right, but it does boggle the mind: fhe fox guarding the hen house? I wonder why? I mean, government crash tests the cars, right? You'd think it would be easy to run independent fuel economy tests on those vehicles first.
    Also, just editorial: "mileage" should read "mpg" or "fuel consumption"?
  4. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    I assume that it's the outcome of funding and politics.
  5. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    did EPA made any money by busting Hyundai, Kia and Ford?
  6. Trollbait
    12,809
    The EPA will spot check about 10% of the models of a given year. New models, and high outliers are likely to be picked, so expect the new Prius to be EPA tested. The limit on how many they test has been funds. Their testing facility went years with out a 4WD dyno.
    I believe fines go into the general fund.
    Ursamajor likes this.
  7. bisco
    52,790
    down here, we say, 'it gets great mileage'. don't ask me why.:rolleyes:
    everything goes into the debt ledger.
  8. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    Toyota also said 18% in European spec... of course under European rules... which is perfectly believable since current Auris and Yaris got better MPG than 2009 Prius, so it is around 8-9% better than latest Yaris Hybrid with Prius c powertrain.
  9. bisco
    52,790
    why isn't 18% there the same as 18% here?
  10. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    May very well be. But it has been said that the Euro spec is weighed more towards city driving.
    So possible to get 18% city increase with EPA and less on highway. Hoping we will see combined ~18% increase here.
  11. spwolf
    3,156
    440
    Eastern Europe
    because test is completely different and can not be compared.
  12. Trollbait
    12,809
    The NEDC gives results higher than the old EPA.
  13. cyclopathic
    3,292
    547
    2014 Prius c
    For the same reason C has higher rating on non-EPA as Gen3 and opposite on EPA.
  14. bisco
    52,790
    was there any increase from gen II to III on the epa?
  15. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Yes:
    Going from Gen 1 to 2 to 3 combined EPA mpg were 41, 46, and 50, respectively:
    Compare Side-by-Side
  16. Mendel Leisk
    42,285
    More realistically?:
  17. energyandair
    905
    339
    Victoria BC Canada
    Prius C has the same rating as Gen 3 on EPA. (4% better in town and 4% worse on highway offset)
    Comparing the same car on the City vs Highway tests. The Prius C varies approx. 14% and the Gen 3 varies approx. 6%
  18. Mendel Leisk
    42,285
    Sorry, what are those last two percents, highway vs city?
  19. energyandair
    905
    339
    Victoria BC Canada
    Yes
    Prius C: 7 mpg difference between the two tests = 14% of 50 mpg
    Gen 3: 3 mpg difference between the two tests = 6% of 50 mpg
  20. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
