2016 Prius 4 rear quarter panel and bumper damage
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Cease1955, Jan 18, 2020.
  1. Cease1955
    Cease1955 New Member
    puyallup wa
    got tagged by hit and run. insurance company said wont replace just repair quarter panel and replace bumper skin. I don't like idea of bondo, or body fillers on my cars. Judging from photos I have down loaded, do you think quarter panel can be repaired so that I wont be able to tell any damage had occurred?
    Thank you for your input.
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    Why don’t you ask a body shop or two how they’d do the repair, and how much filler they’d expect to use? It wouldn’t surprise me if a skilled craftsperson could restore the panel to its original shape—maybe even using paintless dent repair techniques—but it’s difficult to write a collision repair estimate just from a photo.
    Replacing the entire quarter panel would be a much more invasive procedure; regardless of cost, I wouldn’t want it done unless necessary. As shown in catalog Figure 61-01, Side Member, image 615441A, the outer side panels are made in one piece at the factory, but they are sold as service parts and replaced in cut sections. Details of the required cutting and welding are in the Collision Repair Manual (more info) under Vehicle Exterior: Body Panel: Quarter Panel: Assembly Replacement.
    Also, note that the blind spot monitor sensor is behind the bumper cover. After the sheet metal repairs are finished, make sure someone does the inspection described in the Repair Manual under Audio/Visual/Telematics: Park Assist/Monitoring: Blind Spot Monitor System: Operation Check.
    kithmo and Mendel Leisk like this.
  3. Mendel Leisk
    42,271
    A good body shop will make all the difference. One that doesn't cut corners, does seamless body restoration (some filler is likely necessary, I wouldn't stress over it), replaces any lost fasteners/brackets with stock parts, and last but not least: uses good paint blending technique, where they thin out the paint, till they're shooting just clear on the last and most extensive coat.
    For the pushed-in quarter panel, I would guess they'll tack weld a series of weld nails on, use them to pull it out, snap them off and grind/fill/sand.
    Judging from the pic the rear bumper won't need replacement.
    Interesting video, a similar repair, done by a mobile body work guy:
    Funny, as I was first watching this, I gradually started noticing it's in the Vancouver, BC area, local to me. :)
    #3 Mendel Leisk, Jan 18, 2020
    kithmo likes this.
  4. Tande
    Tande Active Member
    551
    337
    Mich.
    Yup......around this area, the paint-less dent removal guys preform magic.......might be worth asking......
