2016 Prius AC issues?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by BLITZ XW50, Aug 23, 2017.
  1. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    2016 Prius three.
    I don't know if i'm the only with this issue so far but for the past couple days my AC has been working on and off. Not regulating temperature.
    Let me explain:
    Inside I usually have it set to 72-74 to keep it modest and it'll blow cold but lately nothing but hot air no matter if it's on Normal or ECO, circulating or recirculating air. The only time it would start to get a little cold when at a stop waiting for a light or parked and idle. As soon as I'm back in motion the air heats up again as if I had the heater on.
    Car is currently dropped off with Toyota to check out the problem and I was wondering if anyone else has had this or something similar happen to them.
    52,849
    is it under warranty?
  3. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    Waiting for the phone call from the dealership but I would assume it be covered under warranty especially with a meager 15,500 miles on the car. Will update more after i get info from their service department
  4. Just.Drive.It.
    Just.Drive.It. New Member
    27
    25
    Here, There, Everywhere. Driving my Prius!
    72-74? I would bake! You have the heater on! Try turning it down to 65 or Lo.
    And just drive it.
    kithmo and RCO like this.
  5. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    LOL...I run the A/C in the car at 77 Deg F and that's too cold at times for my wife and I...:)
    pilotgrrl and RCO like this.
  6. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    When it's 85-100 degrees outside the 72-74 is a moderate temperature. :LOL:
    But as for an update: I picked up the car from the dealership yesterday seemed like the only thing wrong with the AC that they could tell me was that the freon was low and needed to be charged. Leak test and pressure test done with nothing else to be found.
    RCO and Prodigyplace like this.
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    The refrigerant doesn't just disappear as if by magic.
    I strongly suggest that you take it in AGAIN in 6 weeks or so and have it checked again......assuming that it lasts that long.
    And KEEP copies of your service tickets in a safe place........so you can document this when/if it finally fails completely AFTER your warranty expires.
    RCO likes this.
  8. Mendel Leisk
    42,343
    Yeah ignore this guy.
    That seems fishy. It was working fine, then its low, so soon? I wouldn't be surprised if it drops pressure again.
  9. bisco
    52,849
    agreed. should get how many years in a good system? i'm over 5, does usage affect length of time?
  10. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    Will definitely be keeping tabs on the AC system and making sure it stays in working order (especially during the warm weather). Thanks for the heads up and for sure I always keep records of everything for the car.
  11. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    I wondered the same thing. Does maybe sitting in the car idle for 30-40min 3-5 days a week for lunch or any other reason you would sit in an idle car with AC running make the "low freon happen? Kind of weird.
  12. bisco
    52,849
    a lot of people live in hot area's, so i doubt that's the problem. will be interesting to see how she holds up.
    BLITZ XW50 and Mendel Leisk like this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    My wife's AC in her non-Prius car suffered the same problem. The dealer found the Freon level low and topped it up. That was over a year ago and it's still going strong, so if it happens again they need to check the HVAC for leaks.
    Here's hoping all's well since the top up.
    BLITZ XW50 likes this.
  14. Sam Spade
    2,036
    1,024
    2017 Prius c
    NO.
    The odds are VERY high that there is a leak and the problem will be back regardless of what you do.......or don't do.
    pilotgrrl likes this.
  15. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    My AC ran at 80 F all time.
  16. lech auto air conditionin
    830
    606
    261
    san francisco
    I would get a good strong flash light and look through the bumper grill. You will be looking for light dark circles ( oil spots ). I have some photos in my photo album you can visit that and see what to look for. Don't let Toyota dealer off that easy. They just get you out of warranty with a cheap quick refrigerant recharge. The when you are out of warranty you will have to buy a condenser and recharge refrigerant at FULL PRICE $$$.
    On the work order did it say they added UV trace dye ?. If so you can buy a UV LED light maybe you can find the leak.
  17. Media_Tech
    Media_Tech Junior Member
    inside the Beltway
    Owners manuals for cars with conventional belt-driven compressors sometimes suggest that compressors should be run for a few minutes every month year 'round to help maintain the compressors' seals with the intention of avoiding refrigerant loss. I have no idea if such advice would be pertinent for an electrically-driven Prius (or in my case a US Corolla Hybrid) compressor.
  18. Mendel Leisk
    42,343
    I've heard that too. True or not, seems sage advice for keeping on top of your AC's condition.
