2016 prius battery type
Discussion in 'Gen 4 Prius Main Forum' started by lovepeople, May 1, 2022.
  1. lovepeople
    lovepeople New Member
    New Zealand
    I bought 2016 prius hybrid few days ago. But I dont know hybrid battery type whether Li-ion or Nimh. How can I check it??
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Not sure about NZ models - all Australian were NiMH. This is from USA source - but not sure if it's universal:
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Welcome and congratulations!! That depends on the trim level. In the US, in 2016, trim 2 is NiMH, trim 2 ECO and higher are lithium. NZ may be very different. There should be PDF brochures available online.
  4. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
    From an Australian article on 2016 Prius, I'm betting New Zealand got the same versions:
    2016 Toyota Prius pricing and specifications - Drive
    The fourth-generation Toyota Prius retains the same 1.8-litre petrol engine, albeit with substantial re-engineering, as well as still sticking with a Nickel-Metal Hydride (Ni-MH) battery instead of the lithium-ion system found in the current Toyota Prius V.
    Ok, this is FINAL, you have a Ni-MH battery, there was no Li battery put in a Prius in New Zealand in 2016, also none in Australia it seems.
    2016 Toyota Prius Brochure
    https://www.toyota.co.nz/globalassets/documents/brochures/2016/prius-brochure-04-16.pdf
    #4 Hidyho, May 2, 2022
    alanclarkeau likes this.
  5. Jburner
    Jburner Member
    68
    44
    Wisconsin
    Check for ZVW50 (NiMH) or ZVW51 (lithium) inside the drivers door where your VIN, Paint code, manufacture date is located. .
