2016 prius c check hybrid system problem. not going into ready
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by papah, Feb 19, 2025.
  1. papah
    papah New Member
    22
    washington
    2016 Prius c
    Hi? i am new here, i noticed the coolant was not moving in the reservoir, i had two flash of the over temp on the dash but doesn't stay on. i bought the inverter pump, i drove the car into the garage to change the inverter pump and coolant as well. i disconnected the battery, i removed the inverter completely out to get access to the pump. i removed and replace the pump, connect all the wiring and hoses. add coolant, i tried to start the car, everything turns on but it will not go into ready. the message pop up check hybrid system, pull over, . the dash light icons stays on. i used obd to check, it says no code. prior to doing the replacement of the pump, there was no obd code. please help.
    i tried removing the white wire in the fuse box still no start. i need guidance on what to do next.
    thank you very much for your wisdom and ideas
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    If the hybrid system does not start, there is a reason for this.
    I have a guess that you did not latch the connectors somewhere.
    Your scanner does not see the codes because the hybrid codes are specific and not all scanners can detect and read them.
  3. Brian1954
    Brian1954 Senior Member
    2,671
    1,069
    South Central PA, USA
    Did you remove the orange safety plug from the hybrid battery when you worked on the car?
  4. papah
    papah New Member
    22
    washington
    2016 Prius c
    Yes i removed the orange plug and when i was done working on the inverter, i plugged it back. all plugs were put back and screw down. all bolts removed were install and no bolt left out or left over.
  5. papah
    papah New Member
    22
    washington
    2016 Prius c
    hi , what scanner do you recommend to used?
  6. MAX2
    MAX2 Senior Member
    1,436
    490
    101
  7. Brian1954
    2,671
    1,069
    Make sure you slide the lever, step #3. Many people fail to do the last step.
  8. Brian1954
    2,671
    1,069
    See post #37 in the thread linked in post #6 above.
    The Autel AP200 is an excellent choice. It is $60 + tax on Amazon.
  9. papah
    papah New Member
    22
    washington
    2016 Prius c
    thank you. i did. orange clip is pushed up and connect with the other socket on the side of it.
  10. papah
    papah New Member
    22
    washington
    2016 Prius c
    thank you very much
  11. papah
    papah New Member
    22
    washington
    2016 Prius c
    car still not starting after removing inverter and replacing the pump. i am still not able to get codes from the vehicle.
    there is a terminal at the back of the inverer while i was threading the nut back on to that terminal there was an electrical spark. i forget to disconnect the 12volt battery when i worked on the car. could the spark destroyed the inverter or or fuse. i believe that wire to the inverter is the dc/dc inverter wire.
  12. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Engine not starting?
    What does it look like? "Ready" not ?
    Motor generator not turning?
    Motor generator turning but internal combustion engine not turning?
    Did you buy some kind of device to read codes?
  13. papah
    papah New Member
    22
    washington
    2016 Prius c
    everything include radio turns on. can move into gear and out of gears. but it will not say ready. when i walk next to the car with key in hand and driver door i hear sounds in the hood but will not go into ready and will not move . all else will work just fine. the inverter pump i replaced is not getting power because all the new coolant i added is not suck it like wise the radiator coolant is not being sucked in.
    yes motor generator not turning on
  14. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    What is the voltage on your auxiliary battery?
  15. papah
    papah New Member
    22
    washington
    2016 Prius c
    vehicle is not at my reach but as soon as i get to it, i will get the voltage and post it
  16. vvillovv
    vvillovv Senior Member
    4,337
    1,518
    NY
    My two suggestions are; check for blink codes, make sure you bring a diagram of the two pins that are shorted with you under the dash because you are looking at the ODB2 port upside down and backwards. If you short the wrong pin numbers it can blow a fuse or worse.
    The other suggestion is go all the way back and recheck all your work.
    Or get the repair manual subscription and read what it says about the work you've said you completed correctly.
  17. papah
    papah New Member
    22
    washington
    2016 Prius c
    hi? the battery read at 13.4 volts. with dr. prius app scanner, it say the pack voltage is 154.75 volts. before the removal of the inverter to replace inverter pump there was no problem or codes beside not seeing the inverter pump movement and flash of hot temp icon. i found these codes p0a0p, p0aod, u0110.
    the inverter was replaced with another inverter still the car is giving same error codes and not going into ready . still saying check hybrid. the orange plug was check and put back in no bet pins .
    thank you
  18. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    This error P0A0D is enough and the Prius will not try to start.
    When the power management control ECU detects that a safety device is operated, it will prohibit hybrid system operation or shut off the system main relay. There are three safety devices in three different locations. The first safety device is located at the service plug grip. The second one is located at the frame wire that is connected to the inverter with converter assembly. The third one is located at the inverter terminal cover where the motor cable is connected to the inverter with converter assembly. If the service plug grip, inverter terminal cover, or frame wire is removed, the interlock signal line will be open. If the vehicle is being driven, this condition will be determined to be an open circuit and the system main relays will not be shut off. If the safety devices are re-installed correctly, the system will return to normal when the ignition switch is turned ON (IG).
    All connections must be rechecked, including the orange safety connector, which must be correctly inserted and locked into place.
  19. papah
    papah New Member
    22
    washington
    2016 Prius c
    Thank MAx2, the black wire that connect to the back of the inverter terminal on the same where the orange cable enter the inverter, below the orange cable, the black wire attached to the inverter, that is the place where the spark occurred when i was putting back the nut on the terminal. the wire is in a black plastic cover. that inverter has been replaced with another inverter. still no start. that black cable where did it go or where is it attached to? is it attach to the frame or fuse box?
    orange plug at the battery is back on solid and connect to the small socket beside it. all the wire and bolt on the inverter are installed and tight.
    if you have pictures of the ground safety devices please post them . i located the inverter cover device.it is on one of the cover plate.
    #19 papah, Mar 26, 2025
  20. MAX2
    MAX2 Senior Member
    1,436
    490
    101
