2016 Prius C hitting 20k
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by emune, Feb 4, 2020.
  1. emune
    emune Junior Member
    26
    2016 Prius c
    Hey guys I’m about to hit 20k on my 2016 Prius C
    Have been doing all the maintenance myself since I got the car
    Oil changes every 5k
    I have an aftermarket washable cabin filter I always clean when I do the oil changes, top off fluids and I have CAI from injen so I clean that filter as well
    I clean the battery air filter in the back under the seats (if there is an aftermarket filter for that I would buy it too, let me know)
    Any one recommend any maintenance, tips or things I can do to keep my car as healthy as I can ?
    I plan to keep this for life
    Thanks in advance
    73411B33-7377-4D61-8C78-D28B8D06C52D.jpeg 03C75EF0-ECDD-4C0B-AEAC-AD1215BCEBB9.jpeg
    dig4dirt likes this.
  2. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    You should plan on the car needing a new hybrid battery every 8-10 years. Right now they are just over $2k, so if you set aside about $250/yr you'll have it covered. You should also plan on a new 12v battery every 4-5 years, budget $250 for that item by itself. Probably due this year if yours is original.
    Don't forget to replace engine coolant, inverter coolant and brake fluid, the schedule recommended by Toyota is good enough. It's in the owner's manual and also available from techinfo.toyota.com
    Consider replacing the transmission oil- According to Toyota it's fine to leave in forever, but some people like to replace it every 50k or so.
    We've just rolled through 38k on our 2018.
  3. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Kudos for DIY'in!
    +1 on the trans fluid.
    brake insp and lube job every 3yr or so.
    About 47K on my 2014
  4. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Are those wheels covers on the sides bolted to the bumper and car panels? if they are, the holes where the bolts go will rust with time, unless these holes got primed and painted after being made
  5. bisco
    52,880
    Follow the months/years schedule, not the mileage
