2016 Prius cutting throttle under heavy load/hard acceleration
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by RedBlueFoX, Oct 29, 2025.
  1. RedBlueFoX
    RedBlueFoX New Member
    Poland
    Recently, my imported from the US 2016 Prius started having an issue, where under hard acceleration it would cut the throttle, above let's say 40-60 km/h. While holding the pedal down, it would stutter occasionally and halt acceleration almost completely. Releasing the throttle to a position below ~80%, the car will ride without any issues. I don't think it's a hybrid issue because the overall fuel consumption didn't change. I still average 3.0-3.5 l/100km when I'm driving alone, and it only happens at above urban driving speeds when I want to press the pedal all the way down. Accelerating at a slower rate and the car can easily do the highway speeds of 140 km/h.
    I've changed the fuel pump assembly from another 2016 Prius with higher mileage(200k miles/330k km), and the air filter to the new one, and all changes were done before the issue appeared. The issue itself appeared after I had replaced all tires with a set of new, better-performing tires. I've tried switching the MAF sensor from another Prius that drives fine, and the issue persisted. The last thing I did was I tanked at a different gas station than usual and put the fuel line cleaner product in.
    Just to add in:
    • Dr. Prius app shows the cell difference at 0.1V
    • Battery state and temperature do not affect the issue.
    • The Short Fuel Trim spikes momentarily before the throttle cutoff and then dips immediately.
    • The local dealer will most likely refuse to inspect the vehicle since it was imported from the US, and multiple local mechanics took a brief look and could not pinpoint the issue.
    • No Check Engine light present, but a lot of archived OBD codes after every scan.
      • One mechanic asked me to keep flooring it after the issue appeared, and after approximately a minute of stuttering, the Christmas tree lit up and the car shut itself down. Restarting the car cleared the Christmas tree and only left a Check Engine Light on with P3190. After clearing the code approximately a month ago, the car has kept driving without the check engine light to this day.
    • Replaced the spark plugs with original Denso plugs.
    If anyone has any ideas what could be the cause, I'd be happy to listen.
  2. Mendel Leisk
    42,331
    Wouldn't hurt to ask them.
    52,831
  4. BiomedO1
    BiomedO1 Senior Member
    4,576
    2,404
    Left Coast
    Nice write-up....
    The issue seems to be isolated to your engine (P3190) not outputting the power that's required under heavy acceleration. Could be a simple sensor or clogged exhaust pipe. That's assuming the fuel pump is keeping up with demand, injectors aren't clogged, compression is good, and air box is clean and clear of obstructions. An OEM diagnostic scan tool needs to be used to check basic functions and see if any sensors are on the borderline of failure.
    FWIW; swapping out used parts from an old car with higher miles isn't a fix, just a diagnostic tool. You don't know the condition of those parts and you've said that it came from a higher mileage car. That same part may also be defective, worn out too.....
    Just something to think about.....
  5. Brian1954
    Brian1954 Senior Member
    2,671
    1,069
    South Central PA, USA
    My guess is a bad fuel pump.
  6. RedBlueFoX
    Poland
    I totally understand it, and it was merely a way to quickly narrow down the list of possible culprits. If changing a MAF sensor from a car that drives fine won't change a thing, and that other car drives fine with the MAF sensor from my car, then it's very unlikely the MAF sensor is the cause of the issue.
    BiomedO1 likes this.
  7. BiomedO1
    4,576
    2,404
    Left Coast
    That's exactly correct.:) I didn't know that the parts car was still running.
    The other thing you need to know is that the ECU holds basic sensor maps; so when you swap a minor sensor part - it thinks it is still the old part. You need to disconnect the 12VDC battery for at least 0.5 hours to erase all the ECU mapping. The car will run weird for a bit as the ECU remaps everything. That would be the proper testing procedure to ensure everything is fine and you have a valid test.
    Try some injection cleaner in your next tank of gas and maybe switch gas stations.
    Hope this helps.....
    #7 BiomedO1, Oct 30, 2025
  8. RedBlueFoX
    Poland
    I definitely forgot to mention that. I did try putting fuel system cleaner, but it did not help. I was also considering trying to run a higher octane gas, just to cross the detonation as a possible reason
