2016 Prius door auto lock
Discussion in 'Gen 4 Prius Technical Discussion' started by Biocide, Dec 8, 2017.
  1. Biocide
    Biocide New Member
    Kimberley, South Africa
    Hi
    I just bought a carista dongle, installed it and I could disable the reverse beeping sound, but no where in the carista app do I see a function to enable or disable auto door lock with speed or lock door when in drive or unlock door when in park?
    Anybody got any ideas what I can do?
    Thanks
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    If your car has a Toyota navigation or multimedia system, you may be able to customize the door lock parameters using that system, under one of these menus, depending on which system you have:
    • APPS > Setup > Vehicle > Vehicle customization > Door lock settings
    • MENU > Setup > Vehicle > Vehicle customization > Door lock settings
    • MENU > Edit/settings > System > Vehicle settings > Vehicle customization > Door lock settings
    • SETUP > Vehicle > Vehicle customization > Door lock settings
    RCO likes this.
  3. Biocide
    Biocide New Member
    Hi my head unit doesn't have the sat/nav, I think it's a non entune head unit :-(
  4. Elektroingenieur
    2,515
    3,288
    Three Touring
    The head unit doesn’t necessarily need navigation or Entune, as long as it has an APPS, MENU, or SETUP button.
  5. Biocide
    Biocide New Member
    Elektroingenieur likes this.
  6. Biocide
    Biocide New Member
    Thats all that I can change from my head unit
    RCO likes this.
  7. Elektroingenieur
    2,515
    3,288
    Three Touring
    Thanks for sharing the photos, but I’m afraid you may be out of luck, then.
    It could be that Toyota had to disable the other door lock customizations due to regulatory requirements in your country, or in the country in which your car was originally sold.
    I suppose you could try using a Toyota Techstream (or GTS, Global Techstream) diagnostic system to do the customization, but I can’t promise a better result. Your Toyota dealer might also be able to assist.
    RCO likes this.
  8. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I am in the UK and the auto lock at speed or when selecting drive isn't applicable in our market either. This is a shame as I've had auto door locking on my cars for years now :(
    You can press the lock button inside, but if a passenger tries to get out they can't. On my other cars it would automatically unlock, some cars needed a second pull for it to open.
    RCO likes this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That's like my MB was
    Harters likes this.
