2016 Prius Eating Tires
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by pleasedpriusowner, Feb 3, 2018.
  1. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    There are a lot of replies already, and I haven't read them. Don't have time, but I will give you my thoughts and it might be helpful anyway.
    I seriously doubt Toyota would have let this out with a design flaw.
    Assuming neither you nor a previous owner have been in a crash that might've bent the frame, I'd rule that out.
    Now, let's thing about what else could cause the camber to be jacked up:
    1. Carrying too much weight in the back of the car, such that the suspension is compressed beyond what is expected and it results in the camber being off as you described. Yours is a Gen 4, which I believe has double-wishbone rear suspension, which should maintain the camber angle. It would have to be pretty heavily loaded to the point it is at the extreme end of its travel. Are you carrying a lot of weight in the car, (esp. rear-biased) so that this might be what's happening? If so, replace the springs on the rear shocks with heavier ones, so it isn't riding so low.
    2. Springs are worn out or shock(s) are blown, causing it to ride low and cause the same issue described above.
    3. You say it is "chewing up tires" and wearing the inside faster than the outside. I would say that if the tires are lasting as long as they should be, but are just wearing a bit unevenly, (i.e. not bald on the inside before 40k miles or so) you don't necessarily have to worry about it. Just get new tires. It might be
    4. Is it the inside of all four tires, just the rear or just one side of the car? If it's the ones on one side of the car, it could just be that the crown of the road is causing it. For example, if the road is crowned such that you're leaning right and you often drive in that lane, the inside of the left side tires would wear faster, and the outside of the right side tires. Vice versa if you're often on the left side of the road's crown. Mix it up a little and make sure you keep up with tire rotation. (I'm sure you do, if you're the kind of guy who gets frequent alignments)
    Let us know what it turns out to be. (if you haven't already)
  2. padroo
    padroo Senior Member
    2,763
    2,253
    I have heard of obese people causing tires to wear.
  3. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Those with unusable "spare" tires. Good one!
    pleasedpriusowner likes this.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    My BMI=32, no problem. If I do have a problem I'll put another 3 psi in the drivers side tyres. :p
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Didn't the OP say in the last post the issue was repaired and that he had hit a dead Deer in the road?
    kithmo likes this.
  6. pleasedpriusowner
    pleasedpriusowner Junior Member
    17
    Toledo, Ohio
    OP here...yes. that is correct. Ran through the deer as opposed to into the deer...didn't have any sheet metal/glass/plastic damage.
  7. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    You mean like this? :D
  8. pleasedpriusowner
    17
    Toledo, Ohio
    Pretty much!
    Salamander_King likes this.
  9. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Did someone say "obese?" :ROFLMAO:
    I wish my Prius would eat the tires! I can't wait to get rid of these damn noisy Michelin Premiers!
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,551
    2,591
    Taylors, SC
    Cusco has just released adjustable rear upper control arms for the Gen 4 Prius. These allow for camber adjustment. A little pricy at a little over $500 a pair.
  11. William Redoubt
    1,228
    1,174
    You mean the, "Tire of Choice"? Here I was suffering from brand anxiety because I bought Hankook 727s at less than $50 each from Amazon.
    Starship16 and krmcg like this.
  12. Starship16
    1,348
    1,455
    Beach Christmas
    I got serious doubts about that "brand of choice." Even the Michelin MXV4's I had on my 2005 Camry were noisy as all heck. They perform well enough... but just LOUD on all road surfaces. Drives me nuts.
    Nobody believes me, but my lady friend has a 12 yr old Ford F-150, with old tires, and that big truck is quieter than my Prius. Much less road noise than my Prius. Maybe because the truck is higher off the ground, I don't know.
    #32 Starship16, Sep 15, 2018
  13. William Redoubt
    1,228
    1,174
    Noise is an environmental experience, relative to the mitigation measures applied. Lower levels of road noise are achievable, as experienced in high-end brands such as Lexus, Acura and Lada.
  14. pleasedpriusowner
    17
    Toledo, Ohio
    TTHANK YOU! This is great to know!
    Georgina Rudkus likes this.
  15. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    Camber and toe can be adjusted on any car with a full or half ring kit. Almost did that but decided it was not a significant problem.
    But this thread brings me to the decision to trade at 50K or buy the extended warranty.
  16. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Knocking Michelin’s is certainly a tell.
    Obviously, the ford has better noise deadening, Prius has “none” in the wheel wells or doors or ceiling, spend some time and money on duramat and silence will ensue.
    audiodave and krmcg like this.
  17. ETP
    2,804
    1,170
    Auburdale FL
    3 fat women plus the driver will over load this car.
    Michelin’s is like a religion to some folks. I converted many years ago after several bad experiences. They started out being the only quality tire company in the world but that has all changed. Bridgestone was one of the worst and is now one of the best. So far Pirelli is working out fine. Call me at 50K.
    Also Yokohama mamas seem to be quality tires.
    #37 ETP, Sep 23, 2018
  18. ETP
    2,804
    1,170
    Auburdale FL
    Wish I had a mini hybrid truck. This bigger is better crap by the auto companies is got to go.
    Like the Chinese 3 wheeler truck.
    3 Wheel Truck, 3 Wheel Truck Suppliers and Manufacturers at Alibaba.com
  19. mglenn
    mglenn Junior Member
  20. ETP
    2,804
    1,170
    Auburdale FL
    I think he got it fixed in one post??????
    There are some full surface wheel kits that will correct this problem for most cars. Castor is the tough one but a full surface kit should work for camber and toe if available.
    Also after market or new OEM suspension parts may help.
    Did you have an accident?
    You need a little negative camber for stability.
    There are time limits to file for the lemon law.
    If it is out of specks they should fix it in the first 36K. Period.
    Also you may consider trading it. 50K for tires is not bad / 36 k is bad.
    how to fix negative camber - Google Search
    Most effective way to fix rear camber? - Honda Pilot - Honda Pilot Forums
    Adjusting Rear Suspension
    #40 ETP, Nov 3, 2018
