2016 Prius Eco
Discussion in 'Gen 4 Prius Main Forum' started by Gokhan, Sep 9, 2015.
  1. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    uh - I believe the VW XL1 got about 120mpg on diesel only.
  2. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Yes on paper it did....
    52,767
    paper is an energy source.
    Maxwell61 likes this.
  4. Gokhan
    Gokhan Senior Member
    6,692
    2,651
    Paramount CA
    When I made that introduction, I was mainly referring to the thermal efficiency of the engine, not the MPG.
    VW has made many claims regarding their diesels, and now that it's all exposed, we know that none of them are true.
    Toyota's Atkinson cycle seems more efficient than the diesel cycle, at least for automotive applications. Also, given that VW XL1 has such a small engine, highway mileage would be poor, lowering the actual MPG greatly.
    On paper, that's for sure. My guess: Given that the diesel Golf gets 36 MPG in EPA tests that are very close to real-world driving, XL1 would get 40, perhaps 45 MPG. Its highway mileage would probably be worse than the Golf, as the 1 L diesel engine would be running in a very inefficient region with the car doing 65 MPH.
  5. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Not from what I've read.
    My impression is that at least one claim is untrue and that VW can't be trusted.
    Being untrustworthy means that other claims could well be false also but I don't know that they are.
    Trollbait likes this.
  6. Trollbait
    12,800
    That has to qualified with "in a hybrid". Without the electric, or even hydraulic, motors to supplement the ICE, most people would pass on the reduced power output of an Atkinsonized engine. With their low torque range, a diesel can give the efficiency and the power alone.
  7. frodoz737
    frodoz737 Top Wrench
    4,790
    2,557
    33
    I can hardly wait for the problems ULS gasoline causes.
  8. Gokhan
    6,692
    2,651
    Paramount CA
    The only effect of ULS gasoline I'm aware of is that oil life increases due to less acid build-up from sulfation and therefore engine life increases as well. You can also increase valve life in direct-ignition engines by using less detergent in the oil (low-SAPS oils) as there is less acid to neutralize. Less detergent reduces ash deposits on the valves that results from burning of the detergent. Low SAPS also helps with emissions, catalytic-converter life, oxygen-sensor life, and especially the diesel-particulate-filter life. We've had ULS gasoline in California for decades and it's time for the rest of the US.
    #128 Gokhan, Sep 26, 2015
    Trollbait and bisco like this.
  9. UsedToLoveCars
    448
    102
    on paper it was supposed to make over 200mpg.
    the production version got 120.
  10. UsedToLoveCars
    448
    102
    wikipedia claims 40% thermal efficiency for diesels, 38% for atkinson. Too close to say which is more efficient than the other.
    though diesels will never be good engines for hybrids because they are more sensitive to engine temperature to get peak efficiency.
  11. Gokhan
    6,692
    2,651
    Paramount CA
    Well, Generation 4 Prius engine for the core model is said to be over 40% efficient. The Prius Eco engine could be even more efficient.
  12. Trollbait
    12,800
    Not likely. Most fuel efficient trims involve areo tweaks and weight reduction, maybe different gear ratios in a traditional transmission. If the engine is more efficient, why not spread the costs and put it in all the trims.
    Toyota's new small(2.8L?) diesel has 48% efficiency.
  13. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The "eco" in Prius eco stands for "economy", not "eco friendly". It's a "stripper". For those on a budget. Yup, the stripped down models often do get better mileage. But that is not usually the reason for their existence.
    So the Prius eco won't be doing things any differently than the other models, it will just have no options installed.
    At least that is my understanding based on what Toyota has officially said, reported on this forum.
  14. TCW1184
    TCW1184 Junior Member
    I'm interested to get official specs. I'm pretty consistently getting 58-61 mpg range in my gen 3. Logic says a gen 4 rated for 60 could see close to 70.
    iPad ?
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Peak efficiency figure means nothing if the operating line can't be maintained there. HSD does a superior job than step gears in Diesel.
    giora likes this.
  16. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    44% is the correct number, but Hilux with that engine suposedly gets only marginaly better fuel economy than previous 3.0 model on NEDC:
  17. Mendel Leisk
    42,251
    Ken1784 is posting some interesting information regarding the ECO model in this thread:
    Gen 4 Staff Manual (In Japanese) =/ Specs/Design/Other Info | Page 4 | PriusChat
    In post #67, he lists ECO model deletions, aimed at saving weight. Some of them quite severe: no height adjustement of front seats, and no rear spoiler for example.
    Reading the link (in the same posting), it seems the main, maybe sole reason for the ECO model is to have a lighter model which puts the car in a more favourable mpg testing regime?
  18. Tideland Prius
    16,668
    No rear stabilizer bar. The spoiler is still there (part of the body design).
  19. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I doubt if we see the E grade 'as is' out of Japan.
  20. nagrath
    nagrath Member
    145
    49
    Putnam County, New York
    2023 Prius Prime
    XSE
    WAIT A MINUTE! Isn't that ~75mpg US?
