2016 Prius Eco
Discussion in 'Gen 4 Prius Main Forum' started by Gokhan, Sep 9, 2015.
  1. Tideland Prius
    16,680
    On the European rating. The current one is rated around 62mpg (3.8L/100km)
  2. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    after the VW cheat-a-polooza, I doubt we'll see 4-cylinder diesels in the US ever again. DEF systems are too expensive for econoboxes.
  3. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    The 4 cylinder diesel motors are not the problem...VW cheating is.
  4. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Using DEF / Urea in the diesel exhaust system is like the old 2 cycle engines where you had to mix oil and gasoline. A truly efficient diesel
    engine should not need any type of Urea. So why is it if a diesel goes 60 miles on one gallon fuel it is a polluter so when the same diesel engine goes 40 miles on one gallon of fuel it is not a polluter. Help me on this one I went to public school and can't figure this one out....
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    One reason diesel engines are more efficient is that the peak temperature in the cylinders during combustion is hotter due to higher compression ratios. Unfortunately, that also means they produce a lot more compounds of nitrogen since there is nitrogen in the air and it'll react with oxygen at high temperatures to form NOX. If you run the engine rich, the extra fuel will cool the combustion and prevent NOX production but of course it uses a lot more fuel and pollutes more with hydrocarbons. Those can be dealt with another way.
    Pale Fox likes this.
  6. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    To me it looks like the diesel engine is at the end of its useful ability due to pollutants. VW could only sell their diesel engine cars by fraud not by technology. I believe that current direct injection gasoline engines are the way to go as regular gas is less expensive than # 2 Diesel. Here in Warrenton Oregon, diesel $2.5999 / gallon, regular 87 octane, $2.039 / gallon. Prius (2016) est. 55 mpg on 87 octane, diesel 40 -45 mpg on expensive diesel. So where is the savings on diesel. Also lets not forget paying $3-5 / gallon of DEF/ Urea every 1,000 miles or so with the diesel.
    Again show me the savings with diesel...
  7. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    not everyone lives in Oregon.... in Europe, diesel fuel is 10% cheaper, and TDI's cheat on emissions so they can be relatively affordable and fast, and get good mpg... thats why around 45% of EU drives a diesel.
    frodoz737 likes this.
  8. Trollbait
    12,825
    They are also running lean much of the time, so there is more oxygen available to react with the nitrogen instead of burning with the fuel.
    VW cheated in regards to NOx emissions. The type of fuel has no bearing of how it is produced, but the conditions within the cylinder during combustion, and nothing to do to with efficiency. Well, that is is you want to use less fuel by making more NOx.
    The most efficient gasoline car available for sale was the original 2000 Insight. Its revised combined EPA rating is 53mpg; 65mpg under the old system, and many hypermilers have gotten over 100mpg in it. Part of its ability to sip so little fuel, and that of the older Civic VX and CRX HFE is that engine could use a very lean fuel mix. This results in high NOx production, as it will in any type of engine running the fuel mix lean. The Insight actually had a NOx trap like diesels now use.
    Current DI engines exceed the particulate emission limit that put a filter on diesel's exhaust years ago.
    It isn't all about money. My support for diesel stems from the current advantage it has in terms of sustainable, renewable fuels, and it is not just biodiesel. There is a vegetable oil based substitute that is a better replacement than biodiesel. It is already for sale in California. Audi has a pilot plant making a diesel heavy crude for excess wind power, exhaust CO2 from another plant and water.
    Not that there isn't research going into a renewable replacement for gasoline, but the field is further behind with most being done with alcohols that require different engines to be truly effective.
    Pale Fox and Ursamajor like this.
  9. nagrath
    nagrath Member
    145
    49
    Putnam County, New York
    2023 Prius Prime
    XSE
    So does that mean at least that we can expect ~10mpg increase?
  10. Mendel Leisk
    42,343
    20%? Doubt that very much.
  11. nagrath
    nagrath Member
    145
    49
    2023 Prius Prime
    XSE
    That's why I was surprised at the figures. But while the absolute rating may be off due to the difference in the testing cycle, the increase seems to indicate a pretty decent jump in efficiency. Very curious to hear what the ratings for the (various and as yet unclear) models are, including any possible 4/AWD version.
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    My bet is that the core 2WD model for the US (i.e. not eco) will achieve EPA rating of:
    54 MPG highway.
    58 MPG city
    56 MPG combined.
    What is your bet?
  13. Mendel Leisk
    42,343
    I saw somewhere: highway was gonna be at least as good as city. Maybe the same?
  14. bwilson4web
    16,533
    I've been racking my brain to figure out how to poll this before the official numbers come out. In theory, two polls are enough, City and Highway as the combined is just a weighted average. But a single poll, combined is much easier . . . so many choices.
    Then the fourth poll is 0-60 times:
    • > 9.8 sec. # That MPG better be my range
    • 9.8-9.6 sec. # 9.7 is generally accepted number, no change
    • 9.5-9.3 sec. # Ok, less bad
    • 9.2-9.0 sec. # Humm, will be noticed
    • 8.9-8.7 sec. # Hot Dog, we're having fun
    • <8.6 sec. # Holy Carp! A full second shaved off!!!
    ps. Perhaps all four polls but over in Fred's as a kinda of drinking contest. End them on November 17 and tally up scores: +1 for each correct guess. The "4" pointers get 'a toast' at our respective, local bars.
    #154 bwilson4web, Nov 2, 2015
  15. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    Is there a Poll already created?
  16. Lee Jay
    5,850
    4,036
    The zero to 60 time will be 2.75 seconds in a vacuum.
  17. chinna
    chinna Member
    162
    44
    Bellevue, WA USA
    LOL..
    Can ICE run in Vacuum? I thought it needs oxygen... :)
  18. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Maybe the Plug-in Prius until the battery is exhausted, but then one still has to figure out what to do with the human occupant(s).
  19. Lee Jay
    5,850
    4,036
    You don't need either to get from zero to 60 in that time.
  20. bisco
    52,849
