2016 Prius four wheels
Discussion in 'Gen 4 Prius Main Forum' started by MrLightRail, Jan 13, 2023.
  1. MrLightRail
    MrLightRail Junior Member
    26
    Oklahoma
    My Prius has the 17'' alloy wheels, but there is a plastic insert(s) in them which are showing wear. Can I replace these so I can give my car a new car look? I have the 4 touring version.
    #1 MrLightRail, Jan 13, 2023
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    You can get them through the dealer, but be prepared for the sticker shock on the plastic bits.
    Some have painted them quite nicely with rattle can paint and clearcoat.
    Montgomery and Mendel Leisk like this.
  3. Mendel Leisk
    42,323
  4. MrLightRail
    26
    Oklahoma
    Can you pop off the plastic parts for painting?
  5. Mendel Leisk
    42,323
    I believe you need to take the wheel off, then push them off from behind? Probably the easiest way anyhow.
  6. Mendel Leisk
    42,323
    info:
    xliderider likes this.
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    Yes, this is my understanding of the process. Two tabs, one on each side per trim piece.
  8. OkemosJim
    OkemosJim Junior Member
    Michigan
    I tried removing one of these inserts from the front...and broke it. One definitely has to remove the tire/wheel and push the 2 tabs on each one to release it.
