2016 Prius Hatchback - paint peeling
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by desmondlee, Jul 24, 2019.
  1. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    just wonder if anybody has had this problem
    The paint on the driver side rear quarter panel is peeling off the glass
    We just bought this car used from a dealer and it had a little peeling, but it seems to be peeling more and more
    Any advice - replace that glass?
  2. krmcg
    2,592
    2,389
    Whittier, CA
    This issue has been discussed in another thread. The best advice was to take it your dealer and see if they would cover it (seems like a quality control issue). Others have discussed wrapping them with vinyl, paintng them, or replacing them. They do easily pop off back to front and have something to cut the double-sided tape.
    Do you have a Gen 4 Prius? Or the Prius V that is on your profile?
  3. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
  4. Shepherdess
    Shepherdess Junior Member
    Norwood
    I also have the problem of peeling coating on driver and passenger rear quarter panel.
  5. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    i replaced the plastic glass
    I found a used one on eBay
    it pulls out and the corners are held in by sticky tape (otherwise, the corners bend out)
  6. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
  7. MizzzC
    MizzzC Junior Member
    Virginia
    This looks exactly like my 2016 Prius. I was a bit taken aback that it had so much flaking in 4 short years!
  8. stevelawsn
    stevelawsn Junior Member
    22
    Alabama
    I bought a brand new pair for my 2016 Prius 4 from a seller in Japan on eBay. Toyota factory parts in original wrapping. Local Toyota dealer quoted me over $280 for the pair and I bought these for $128 with free shipping for the pair. Fit perfectly and look great.
    https://www.ebay.com/itm/334880381273
  9. redswissprius
    redswissprius New Member
    Switzerland
    I have the same problem on my 2016 Prius 4 (I live in Switzerland). Interestingly, only the right side is affected. This is the "sunny" side of the car while parked (it's always in the same spot), so maybe the damage is partly caused by UV light? However, it does not bother me and I will not replace it.
