2016 Prius hidden settings
Discussion in 'Gen 4 Prius Accessories and Modifications' started by annexedwa, Apr 16, 2016.
  1. annexedwa
    annexedwa Junior Member
    36
    Fl
    Four Touring
    hey all,
    Is there a way to access hidden settings? Vehicle status etc
  2. icbibafp
    icbibafp New Member
    VA
    Check out carista app. Google it.
  3. BayAreaGuy
    BayAreaGuy New Member
    Four Touring
    I have the app. Where is the OBD2 port located? I can't seem to find it.
  4. booke02
    booke02 Active Member
    391
    415
    Israel
    Look around the engine bulkhead close to the brake pedal
  5. BayAreaGuy
    Four Touring
    Found the OBD2 port! For the curious, on the 2016 it is not on the firewall but on the underside of the dashboard, adjacent to the hood release. Also the Carista app works well. My sanity is restored with only a single beep in reverse!
  6. Kasper
    Kasper New Member
    Buffalo, NY
    What OBD2 adapter are you using?
  7. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    Carista
  8. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    I don't know about 2016, but the 2018 prius OBD2 port is located underneath and to the LEFT of the steering column, NOT the right, or near the brake. Above the brake is where the OBD2 port was located for gen 3. The 2018 gen 4 has a plastic cover over that location, so if it is the same for the 2016 Prius, I can see why annexedwa would get confused... ...I did exactly the same thing.
