2016 Prius ICE Water Pump Replacement
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Vprim, Sep 20, 2022.
  1. Vprim
    Vprim New Member
    Tampa
    Three Touring
    Hello all! Long time lingerer here finally making a post. I have a 2016 Prius 3 Touring with about 155,000 miles. The other day the dashboard freaked out and made me pull over. I plugged in my OBD and the code said the ICE water pump is stuck. Fast forward to today I am trying to replace it, I got all the bolts out but the pump is too long to take out without the frame being in the way. I tried jacking the car by the motor and setting the motor on a separate jack. But I’m at a complete loss now. Anyone have some advice?
  2. Mendel Leisk
    42,380
    Have a look at the attached. A very quick read, I didn't see anything special though.
    amos likes this.
  3. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Simple, according to what Mendel Leisk posted; all you have to do is pull the engine (see the last step). Definitely not something this diy person could handle, but I realized my limitations years ago.
  4. ChapmanF
    19,060
    That makes me sort of glad I'm not driving a Gen 4.
  5. Mendel Leisk
    42,380
    amos likes this.
  6. Elektroingenieur
    2,515
    3,288
    Three Touring
    This is, perhaps, a lesson about the risk of relying on out-of-date copies of the Repair Manual (more info), or conversely, the benefit of Toyota’s continuous revision system.
    Some time after the version @Mendel Leisk kindly shared was published, the procedure was changed. The engine assembly with transaxle now remains in the vehicle but is lowered 50 mm and supported by a jack and wooden block, after which the engine water pump assembly can be removed in a specific way.
    This change reduced the Flat Rate Manual labor time for WATER PUMP ASSEMBLY AND/OR GASKET, R&R (operation 161011, ZVW50 series) from 7.0 hours to 1.3 hours.
    Kaizen in action!
    Mendel Leisk and Doug McC like this.
  7. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    THAT IS VERY GOOD NEWS!! And a lesson learned! Thanks for sharing correct information!
    Elektroingenieur likes this.
  8. Mendel Leisk
    42,380
    Kaizen would be to eliminate the paywall for registered owners. (y)
    Can you give any hints about the “specific way”?
  9. Mendel Leisk
    42,380
    Belabouring I know, but:
    seems more like a bunch of very green engineers, with no none keeping an eye on them, coupled with a woeful lack of editorial review. Probably what woke them up was protest from dealership mechanics.
  10. ChapmanF
    19,060
    Maybe they should credit 3prongpaul for that!
  11. Elektroingenieur
    2,515
    3,288
    Three Touring
    I’d strongly recommend that anyone doing this use the actual manual with Toyota’s cautions and illustrations.
    In the revised removal procedure, after removing certain other components, lowering the engine assembly with transaxle, and applying protective tape, the technician moves the engine water pump assembly “to the right side of the vehicle,” “toward the bottom of the vehicle until the shaft of the engine water pump assembly is free,” and then “toward the front of the vehicle,” after which the assembly can be removed “from the top of the vehicle.”
    I’d imagine it may have been warranty claims, for which Toyota pays for both parts and labor, rather than complaints from dealers, that drove the change in procedure. Perhaps there was a run of defective water pumps, or their failure rate was greater than anticipated—but this is just speculation.
    Doug McC and Mendel Leisk like this.
  12. amos
    amos Active Member
    376
    285
    los angeles
  13. Mendel Leisk
    42,380
    Well disconnecting an engine mount and letting the engine slump down, is a lot less egregious, then “remove engine/transaxle”. Honda timing belt replacement required similar.
  14. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    That’s it in a nutshell. For the little effort required and minimal cost (especially diy) every 50k (with strip testing every 6 months) seems like extremely cheap insurance.
  15. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    When I worked on tractors in the '90s there was a twin cylinder liquid cooled Honda ride on tractor that needed a starter. The bolts that hold the starter in were inserted from behind the flywheel and threaded into the starter. This obviously requires pulling the engine and the flywheel just to change a starter motor. I was determined at that point to figure out why it was Japan had it in for us
  16. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    So the engine water pump on the generation 4 Prius fails in the same way it did in the previous generation, come on, why.
  17. douglasjre
    2,250
    751
    Null, NL
    I haven't seen many water pump failures. What's the story
  18. g4ppowner
    g4ppowner New Member
    I know this is an old topic, but quick question; where can I find this Flat Rate Manual labor time? A shop quoted me 12 hours labor, but this thread seems to imply that there's been an update that should result in less time. Specifically, does this apply to the Prius Prime as well?
    I'm looking at the Repair Manual on tech info, but don't see any reference to actual hours anywhere. Where can I find this?
  19. Mendel Leisk
    42,380
    Take out a short term subscription at Toyota Tech Info and search for the Flat Rate Manual? This is to determine a fair price through dealership service department?
  20. ChapmanF
    19,060
    My TIS subscription isn't paid up at the moment, so I can't confirm for sure whether the Flat Rate Manual is available there. Most of the information from the Flat Rate Manual that gets posted here gets posted by @Elektroingenieur, who might chime in with more information. (Seems like I haven't seen @Elektroingenieur for a while around here, though.)
