2016 Prius Low MPG
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by jyii07, Jun 16, 2022.
  1. jyii07
    jyii07 Junior Member
    39
    NYC
    Hi All,
    I have a 2016 Prius 4 with around 120k miles. The avg mileage dropped from around 55mpg to around 48mpg the past couple months so I thought spark plugs were to blame. I got those replaced by the mechanic (purchased the OEM Denso ones), replaced the cabin/engine air filters, cleaned out the hybrid battery fan filter, and even inflated the tires. Is there anything else I'm missing that could contribute to the lower mpgs? Coolants were also drained and filled around the 105k mile mark. I was thinking of cleaning out the MAF sensor but wasn't sure if gen 4s required cleaning as often as the gen 3s. Should I go ahead and clean the MAF sensor anyway and see if that helps? Any other ideas?
    Thanks
    52,693
    Tires?
    a/c?
    any driving changes?
    alignment?
    12 volt battery?
    #2 bisco, Jun 16, 2022
  3. jyii07
    39
    NYC
    Changed out two tires around 10k miles ago (no changes in MPG after the change). Driving habits are the exact same. Alignment looks fine. I'm in socal so a/c is always on but I don't see much of a difference when turning it off anyway. Would a low 12v battery affect mpg? Battery was last replaced 3 years/40k miles ago.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Spark plugs were right on time even if they didn't help.
    Low 12V could drag down the mpg a little bit, but don't replace it as a means of troubleshooting; have a load test done.
    When's the last time you checked the brake caliper slide pins. They will eventually stick and cause the brakes to drag. This not only uses more gas, it wears out the pads & rotors prematurely.
    Looks like you covered everything else that I can think of right now.
    Tande likes this.
  5. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    check tire air pressure. I don't think that would have such drastic impact on MPG. When I switched out my LRR tires to defenders, I probably lost 5-6 MPG initially but has come back up since after a few thousand miles. You could try charging the 12v battery if you have a somewhat good charger and see if that helps. Check fluid in 12v battery as well. I find when I fully charge my 12v I get slightly better MPG, nothing scientific but does appear to help. Good luck.
  6. jyii07
    39
    NYC
    A shop replaced all 4 rotors and brake pads at 115k miles and assume (maybe incorrectly?) that they lubed the caliper pins while replacing the rotors.
    Thanks.. ill just refill the tire pressure again. Will check 12v too.
  7. bisco
    52,693
    i suppose new brakes would be a good culprit to take a hard look at. gen 3 had a specific method for rear pad installation, which was easy to mess up. idk about gen 4
  8. jerrymildred
    11,517
    14,164
    Tampa, FL
    They should still be lubed, but not necessarily correctly installed, as @bisco mentioned.
    What happened that they had to be replaced so early? Road salt induced rust?
  9. jyii07
    39
    NYC
    hmm how would I check these specifically?
    Bought the car in NY, moved to socal and got them replaced here. Mechanics here aren't used to seeing that much rust and corrosion on the rotors and maybe they could've lasted longer but it cost me $600 to get it all replaced so I got it done anyway.
    jerrymildred likes this.
  10. bisco
    52,693
    jack it up and see if they spin freely
    CR94, FuelMiser and jerrymildred like this.
  11. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    Both times my 12v battery started to fail I noticed about a 5-6 MPG drop. It wasn't gradual, but something I saw within a week or two. Last time, I removed and charged the battery then load tested it which immediately dropped to 11v and showed weak. When I took it back to the parts store where I bought it they said it tested good but replaced it after I explained what was happening. The very next drive the MPGs were back up to normal.
