2016 Prius Lower Console/Shifter Appliqué Package
Discussion in 'Gen 4 Prius Accessories and Modifications' started by NorCaGuy, Feb 9, 2016.
  1. Dan C
    Dan C Junior Member
    I just ordered the black replacement for my new 2016 (if you have patience you can get a great deal!)...anyway, I'm starting to wonder how bad fingerprints are on the black. The screen and the glossy black area around the screen pick up fingerprints so easily. I assume this will be the same since it seems to be the same glossy black?
  2. Prodigyplace
    12,720
    11,852
    Central Virginia
    Replacement what? My Trim Two console is matte black, not shiny.
    RCO likes this.
  3. Dan C
    Dan C Junior Member
    I have the three and my understanding was that the replacement dash console (being discussed in this thread) is the glossy version, not the matte that is standard in the one and two models.
  4. KaptainS
    KaptainS New Member
    Las Vegas
    Hi Jim,
    I am hoping you or someone else can help me. I have a 2016 Prius and this morning, like a idiot, I spilled a entire cup of coffee on my Qi charge pad. :-( I was driving but quickly stopped up what i could but it was a decent sized, full cup. ☹️
    Long story short-- I tried everything to dry as much as possible but I'm sure a decent amount fell below. Since you seem super knowledgeable about this-- what is under there? Could I have caused any major damage or is the Qi pad the only wiring at risk? I am mostly concerned about other components being damaged from it.
    I called the dealership and they are charging a insane amount just to remove the console to check. Any help would be SO greatly appreciated!
    Thanks,
    Stacey
  5. KaptainS
    KaptainS New Member
    Las Vegas
    Thanks,
    Stacey
  6. aurelio
    aurelio Member
    72
    56
    Mexico
    You can open it yourself without any tool. You will find cables for the qi charger, bt antenna, power audio and USB connector. Parking brake cables are over there too, and a lot of noise isolating fabric. I found it myself pretty easily, and used qi wiring harness to power a GPS tracker.
    Open the arm rest cover. Pull the vertical plastic plate towards the front of the car from the top. It will get loose easily. Now, place your finger through the free space behind the power, audio and USB connector and pull upwards. Be careful while lifting and loosing the plate. Harnesses are pretty short.
    Done. You can do it in 10 seconds. No tools at all. No ridiculous charges.
    Let us know if it was helpful.
    SM-T813 ?
    RCO and Ferrarilover like this.
  7. bobthejedi
    bobthejedi Active Member
    137
    154
    SF Bay Area
    I just pm'd you the official Toyota instructions on the console remove, pretty easy, as far as whats there is the Qi charger and some wiring
    RCO likes this.
  8. Craig21029
    Craig21029 Member
    40
    77
    Clarksville, MD
    They have. KCWhitney in another thread about the black shifter applique found the steering wheel applique on eBay. It comes from China. Mine came yesterday, it took 11 days. The pic shows a dayglo green applique, but the link has pics that also show a black one. They tell you to indicate that you want a black one in the notes when you order it. Car Steering Wheel Panel Garnish Cover Trim for Toyota Prius XW50 2015-2017 | eBay
  9. Prodigyplace
    12,720
    11,852
    Central Virginia
    How does the steering wheel applique fasten? Does it appear made to last or just for a temporary change of color?
  10. Craig21029
    Craig21029 Member
    40
    77
    Clarksville, MD
    [​IMG] [​IMG]
    Here are pics of it front and back. It appears to have 2-sided tape all around the edge. I hope to mount it tomorrow morning (it's too hot out now). Will post before and after pics. The black plastic looks just like the black plastic of the center console where the Qi charger and cup holders are. I picked up alcohol wipes earlier to clean the existing white part on the steering wheel before applying it. It appears made to last. It doesn't bend at all.
    Hmm, Priuschat doesn't like the pics. I'll retry later.
    #50 Craig21029, Jul 15, 2017
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    One last question. Gloss or matte black? My level 2 Liftback has a matte black console.
  12. Craig21029
    Craig21029 Member
    40
    77
    Clarksville, MD
    It's gloss black.
  13. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    How come so many people don't like the white console? It's the only thing in the interior that doesn't seem to attract dust, and always looks clean. (Plus it sparkles when the sun hits it, and matches my blizzard Pearl paint perfectly).
    Ngenovesi, krmcg and RCO like this.
  14. Craig21029
    Craig21029 Member
    40
    77
    Clarksville, MD
    Ok, I mounted the black steering wheel applique today. The only hard part is getting the red backing off the 2-sided tape. After that, it took less than 10 seconds. It's all-black, the orange/red glow in the middle is reflected sunlight.
    Attached are before and after pics as requested. The shifter applique is being installed this Thursday. Then the shifter and steering wheel will match the center console.
    Mark57, Prodigyplace and RCO like this.
  15. Prodigyplace
    12,720
    11,852
    Central Virginia
    Looks good!
    I wish they had matte black to match the Level 2 console.
    Craig21029 likes this.
  16. Craig21029
    Craig21029 Member
    40
    77
    Clarksville, MD
    I do too. I think I'd like matte black better.
    Prodigyplace likes this.
  17. FernandoRA
    FernandoRA Junior Member
    Mexico
    Bob, do you still have the instructions? I bought my Prius without the qi charger and now that I have a phone with it, I want to still a charger from underneath but I am afraid to break something...
    Thanks!
  18. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
  19. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
  20. steuermann
    steuermann Junior Member
    16
    near Hamburg/Germany
    2018 Prius
