2016 Prius - modify rear tail light assembly
Discussion in 'Gen 4 Prius Accessories and Modifications' started by jcs012, Jun 16, 2020.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    It would need certification for legality - not sure about there, but here, it's unlikely that would happen.
    Prodigyplace likes this.
  2. Prodigyplace
    12,712
    11,848
    Central Virginia
    I found it strange he wants what you posted. Looked like an Australian Prius to me.
    alanclarkeau likes this.
  3. reallyreal
    reallyreal Member
    71
    61
    Italy
    2024 Prius Prime
    Well, regulations may change from place to place, and I don't specifically know for US, but I guess that generally yes, you should certify any change you make to a car.
    That said, from a legal standpoint I don't see how just reducing the height of the led stripes can be any different from putting different turning stripes, different taillights assemblies, changing suspensions, rims size, stop lights, fog lights, tint windows, and any external work performed in this section of the forum.
    Plus, it's not even a 'modification' like those just listed, it's like going around with a burned lightbulb, with the difference that the tail lights would still signal each side of the car and would still be bigger and more visible than those of a Gen2 or a Gen3.
  4. reallyreal
    reallyreal Member
    71
    61
    Italy
    2024 Prius Prime
    Don't know exactly :), but they are LED stripes if I'm not mistaken, so, technically, you may even be able to take individual LEDs off and shorten the lights just a bit. However, it's probably much easier and quick to just disconnect the lower stripe, given it is in a different assembly.
    Possible it's possible, as I've seen someone here going around with just one of them off, not working for some reason.
  5. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    You would not believe how many non-DOT-compliant lighting systems are being used in Florida right now. The average officer isn't bright enough to know that all the people with off-road lighting can be pulled over and ticketed for using them in the streets. But then people aren't being pulled over for having no brake lights, either. I guess it works both ways - nobody gets pulled over anymore unless it's for speeding.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    I assumed California was more strict.
  7. jcs012
    jcs012 Junior Member
    California, USA
    Two Eco
    Actually they haven't been either.
    But anyway, if it's worth more trouble to make these changes, I will probably just upgrade to a newer Prius or a RAV4 Hybrid.
  8. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    I'll be the weird one out and say I prefer the earlier-year zigzag lights, AND wish that the design language had been followed up front as well, with orange zigzags in the headlight housing for running lights.
    krmcg, Harters and reallyreal like this.
  9. Prodigyplace
    12,712
    11,848
    Central Virginia
    Hybrid Pit has a kit to use the zigzag for brake lights too.
    Junack LED Tran Tail Kit for 2016-2018 Toyota Prius
    krmcg and alanclarkeau like this.
  10. reallyreal
    reallyreal Member
    71
    61
    Italy
    2024 Prius Prime
    I like them too, just think they are too long.
  11. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    That I'm not sure I'd want. It's not clear to me whether that kit would introduce 2 levels of brightness to the zigzag, and I run my running lights all the time, so it wouldn't make a difference if it does not.
  12. Prodigyplace
    12,712
    11,848
    Central Virginia
    Running lights do not light the tail lights. Parking lights do though.
  13. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    Parking lights generally stay on with the ignition off... The Prius cuts them off when you open the door. ;)
