2016 Prius Owners Manual
Discussion in 'Gen 4 Prius Main Forum' started by PRPrius, Dec 12, 2015.
  1. PRPrius
    PRPrius Active Member
    327
    198
    Owner's Manual is out!
    Head over to Toyota Owners Official Web Site and select 2016 Prius. The owner's manual is under the resource tab. I tried to upload the file but its too large (800 pages).
    SpecialK, frodoz737 and Mendel Leisk like this.
  2. Netcub
    Netcub Active Member
    344
    170
    Kentucky
    Wow, the navigation looks nearly identical to my 2010...
    Sergiospl likes this.
  3. MrBillTulsa
    MrBillTulsa Member
    174
    35
    In the hills west of Tulsa
    Recommended engine oil = Toyota 0W-20W (same).
    :eek:
  4. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Elsith, telmo744 and TonyPSchaefer like this.
  5. Gokhan
    Gokhan Senior Member
    6,663
    2,641
    Paramount CA
    ILSAC GF-6B oils (xW-16, xW-12, and xW-8) won't be available until 2018, meaning that they won't be specified until Generation 5.
  6. nategold
    nategold Member
    117
    38
    Arlington, MA
    My impression - way too much information displayed, who needs it? Everything done via that main screen, few buttons for common things. How much distracted driver does it take to turn on the defroster or increase the temperature? I worry about that, as I plan on getting a 4G car.
    I stand corrected - there are some air conditioning control buttons in the center, not nearly as convenient as on the steering wheel in the 2nd generation. My comments on distraction and way too much information stand.
    #6 nategold, Dec 13, 2015
  7. Trollbait
    12,775
    That was even a concern with the gen2. Then, moving the controls to a touch screen was to appear high tech. Now, it's to save cost.
  8. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I was going to check the CARB warranty language, but maybe the Warranty is not yet available
  9. bisco
    52,662
    i like the gen III hvac controls, except placement. will be sad to lose any buttons to touchscreen. just using the radio is distracting.
  10. Mendel Leisk
    42,148
    I notice lots of mention of a full size spare in the manual. Seems like an oversight, since the US market at least has either temp spare or pump-and-sealant kit. Perhaps doable though, for any owner, the space is there, IF you throw enough $'s at it?
    Personally I'm fine with a temp spare, but some folks like the a full size spare. Also, might almost be cheaper, than trying to track down a temp spare.
  11. bisco
    52,662
    i don't understand. the models without spares have room for a spare? why don't they have spares, compared to the other models. (except eco which makes sense)
  12. frodoz737
    frodoz737 Top Wrench
    4,770
    2,540
    33
    Why would appx 35 lbs make a difference on the ECO?
  13. Mendel Leisk
    42,148
    My impression, just from the pdf: if you pull out all the styrofoam, there's enough room in the spare wheel well to drop in an inflated 195/65R15. Once someone has opportunity they can check on it.
  14. bisco
    52,662
    it's the cumulative effect of whatever weight reduction they went through i guess. but the real question is, why did they eliminate it on any models?
  15. Mendel Leisk
    42,148
    There's a monotonous regularity to the instruction for replacing LED lights, headlights included: take it to the dealership.
  16. Trollbait
    12,775
    Mentioned elsewhere, the Japanese test uses a set dynanometer load based on a weight range the car falls into. Removing the spare, using Li-ion, etc. got the Eco model down into an easier weight range than the rest of the trims.
    For other trims that don't have the spare, it could be to balance out the weight of added accessories and options.
  17. bisco
    52,662
    don't forget the rear wiper, that has to be 8 ounces or more.:cool:
    kithmo likes this.
  18. Trollbait
    12,775
    I thought the rear wiper delete was for aerodynamic improvements.;)
  19. bisco
    52,662
    that's just a bonus.:p
  20. Tideland Prius
    16,650
    For those that were wondering about remote-linked power windows
    The Gen 4 has the feature.
    giora and bisco like this.
