2016 Prius PDF Presentations - Chief Engineer & Hybrid Engineer
Discussion in 'Gen 4 Prius Main Forum' started by Danny, Oct 13, 2015.
  1. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Here are PDF versions of the slide stack they used to introduce more details on the 2016 Prius this morning. They are fairly large files, so I've put them up on Google Drive for download.
    Chief Engineer Presentation, by Koji Toyoshima: 20151013_01_02_en.pdf - Google Drive
    Hybrid Vehicle Engineering, by Sunsuke Fushiki : 20151013_01_01_en.pdf - Google Drive
    Pale Fox, cwerdna, Emcguy and 5 others like this.
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Thanks for the info, Danny. Looking around the web, I see a 30 horsepower improvement and a target of 59MPG. That is impressive!
  3. bwilson4web
    16,552
    • Are there any details about when "Toyota Safety Sense P" will be available in the USA?
      • Is it being delayed because of the NHTSA and IIS activity in this area?
      • What could accelerate making it available in the USA?
    Bob WIlson
    #3 bwilson4web, Oct 13, 2015
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Yay! They will move the 12 volt battery out of the passenger compartment! That should make it safer and cheaper.
  5. bwilson4web
    16,552
    Time to start watching for SAE papers from Toyota.
  6. Eclipse1701d
    645
    224
    Three Touring
    I always thought it was better to have the 12 Volt located aft. I was under the impression, when located in the engine compartment, that the heat cycles shorten the life span.
    johndeerrm likes this.
  7. bisco
    52,891
    anything about ev with a cold engine?
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Correct. The risk of having it inside the passenger compartment is entirely on humans, not the battery. I would rather pay for more, cheaper, batteries that do not endanger humans.
  9. bisco
    52,891
    doesn't seem like prius batteries last longer than those in the engine bay, but that maybe due to size more than heat.
  10. bwilson4web
    16,552
    Over in Autoline Daily, they have no clue about the 2016 Prius. The commenters at GreenCarCongress don't understand it either ... so far.
    This car is going to shock the market.
    Pale Fox, KrPtNk and bisco like this.
  11. bisco
    52,891
    looks like toyota really pulled a rabbit out of a hat this time.:cool:
  12. bwilson4web
    16,552
    West Texas Jack Rabbit!
    ps Austin can confirm folks steer around them not only to avoid body damage but punctured tires.
    laevus likes this.
  13. Eclipse1701d
    645
    224
    Three Touring
    Gen III to Gen IV definitely appears to be a much bigger jump in technicality, drive-ability, and performance. It is beginning to look like another successful generation is afoot!
  14. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I hope it won't shock us with it's price! !
  15. civicdriver06
    797
    324
    Germany
    Sounds great !
    New Eco - Mode is current Normal-Mode !
    I assume gen 4. Normal-Mode will be similar to gen. 3s Power Mode .
    If so then what will gen. 4 Power-Mode be like ?
    No word about system power output yet,but up to now the staff manual seems to be pretty accurate,but still I can't believe they reduced it to 122 hp !
  16. Mendel Leisk
    42,376
    Yeah, I noticed that.
    Just reading through the first document, titled "Hybrid Vehicle Engineering", one thing I come away with: a lot of the touted improvements seem to be in comparison with the current model. For me they stretch credulity.
  17. DFGeneer
    DFGeneer Junior Member
    Switzerland
    ..no more planetary gear in the PSD?
    That is a surprise.
  18. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Yes.
    When I first got my gen 3 I studied several on line documents before understanding how a planetary gear set could replace a conventional transmission. Once I did understand it, it seemed like a brilliant and elegant process. It also seemed essential to the operation of the HSD.
    So now I would like a clear explanation how the new Parallel gears work to send power to and from different components and how this change improves efficiency.
  19. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I think it is no more second planetary gear. The main is still there.
  20. Alesf76
    Alesf76 Member
    89
    33
    Italy
    European Auris HSD is already like that, but it's just the throttle pedal response. "Collateral effects" (i.e. a/c slower in ECO and engine idling in power etc.) are kept the same.
