2016 Prius Two Eco - rear brakes, what am I doing wrong
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by King_V, Apr 17, 2026.
  1. King_V
    King_V Junior Member
    Sicklerville, NJ
    Two Eco
    So, I did do a bit of digging first, but I'm wondering if I'm doing something wrong. I've done more than my share of disc brake replacements in the past, and even last year. Never did it on a Prius or any hybrid though.
    I've got about 80k miles on my Prius, and I was told that the rear brakes are very low. Of course, the dealer would love to do it, and insists that the rotors also need to be changed. I can only imagine what they'll charge. I figured I might at least attempt to inspect it myself.
    I am aware of the weird cross-like thing that I'll have to rotate back in if I put new pads on, but at this point, I'm just looking to inspect, and see if I can get the caliper off.
    This is what I did:
    1. Opened car with fob, and opened hood
    2. Disconnected negative terminal of battery
    3. Loosened lugs
    4. Jacked up car
    5. Removed lugs and tire
    6. Realized I couldn't even turn the hub, thus went back and released the parking brake (it's a mechanical one)
    7. Now could turn the hub via hand on the studs, but there's some resistance
    8. Removed caliper bolts
    This is where it gets weird. I completely removed the top bolt, but left the lower on, but very loose (could easily turn with fingers), figuring I could just pivot the caliper without fully removing it.
    The caliper would barely budge. Couldn't do anything with hand, and using large flat-head screwdriver as a pry, I maybe got it to move a hair, at best.
    Are there any extra steps I've missed? I'd really like to give it a try again this weekend, probably on Sunday.
    As a side note - for that part on the caliper that I have to rotate back in, will a typical needle-nose be strong enough to do it, or should I get a particularly heavy duty one because it needs a lot of force? I've read in a few places that the specific tool to rotate it back into place is awkward.
    EDIT: while I'm on this, are the typical semi-metallic pads the norm on a 4th gen Prius, or do I need to get something different?
    #1 King_V, Apr 17, 2026
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,085
    6,947
    Texas Hill Country
    this should work
  3. King_V
    Sicklerville, NJ
    Two Eco
    That looks straightforward enough, but it's the rear brakes I'm working with, and there's some extra considerations like the rotating piston retraction, the car possibly attempting to push the rear brakes even when off (hence why I assume the battery disconnect is required), and so on.
    Just wondering if I had missed something in my steps.
  4. Mendel Leisk
    42,339
    Have a look at the rear brake drag link in my signature, might be related.
    (on a phone turn it landscape to see signatures)
    King_V likes this.
  5. BiomedO1
    BiomedO1 Senior Member
    4,588
    2,408
    Left Coast
    You need to remove both caliper bolts. Some pads has an indexing nipple that slots into the piston. Don't know if yours operates like that. I'm pretty sure that's why you couldn't just rotate the caliber out of the way - like you would do with a front caliber. If it has that indexing nipple - it must be aligned when you put it back together, otherwise you'll be dragging a pad; once the piston pushes back out.
    Hope this helps...
    Yes; don't forget to disconnect the battery - you don't want the piston pushing themselves out.
    King_V likes this.
  6. Fubar XIII
    Fubar XIII Member
    72
    42
    Metro Detroit
    Been there, done that. Twice now.
    My first set lasted 230,000 miles, though they were THIN. Should've done at 200k. Ok, maybe 175k. Live & learn.
    Second set only went about 105k. Those were semi-metallics. Turns out we're supposed to use ceramics. And I thought those were just for high-performance sports cars, et cetera. Put a new set of ceramics on last summer.
    As for the plus sign in the rears, that messed me up, too. I'd never had to do anything like that before. First time I actually cranked it so far the screw came out of the nut. Yup, you can do that! If you go the wrong way. After a few minutes of fumbling around I got it re-threaded and then knew which direction I was supposed to go. Trial & error. You learn more from your mistakes.....
    As for how to twist said part, I went with a pair of medium-sized channel locks. The jaws are solid & won't pop off easily, you can, of course, adjust them, and they put pressure on both sides at the same time which really seemed to make things move a bit quicker though nowhere near fast. Be patient. I held the jaw end of the pliers in my hand and left the handles sticking out the side so I could apply pressure straight down on the part. It doesn't take much force to move it but there is a steady resistance to it, as if you are turning something through thick grease. Steady pressure worked great.
    After you get the screw in far enough to put the caliper back on, you're good.
  7. Mendel Leisk
    42,339
    These gizmos work good:
    Lots of brands available.
    King_V likes this.
  8. King_V
    Sicklerville, NJ
    Two Eco
    Coming back to this later than I'd hope (weather on weekends has not been cooperative) - I'm looking up rear brake pads, and, under both AutoZone and Advance Auto Parts, I see references for two different part numbers for each brand, both of which supposedly fit my 2016 Prius Two Eco, all indicated as being for the rear, and that they fit the car.
    ie: for Autozone
    • Duralast D1423
    • Duralast D1354
    • Duralast Gold DG1423
    • Duralast Gold DG1354
    for Advance Auto
    • Carquest Premium Gold GNAD1423
    • Carquest Premium Gold GNAD1354C
    • Carquest Premium Platinum GNAD1354H
    • Carquest Standard NAD1423 <--- this one specifically has a note saying it does not fit my car
    Definitely does not seem to be a with vs without mounting hardware thing, as none of the 4 for Autozone have mounting hardware included, and all of the ones for Advance Auto have mounting hardware.
    So, which one actually fits, 1354, or 1423?
