2016 prius v fuse scematic
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by bat4255, Apr 19, 2017.
  1. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    This may have been discussed but I could not find it in the manual or through search.
    I am trying to find a fuse diagram that shows what fuses goes to what.
    Right now I am looking for the power ports.
    I did not blow it, but if I do I need to know where the fuse is located.
    Thanks in advance.
    52,849
    should be in the owners manual, no?
    jjmerp likes this.
  3. bat4255
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    No, all it said was the accessories fuses are under the dash and hood. I did find it, as there is a schematic under the cover for the one under the dash, but not for the one under the hood.
    52,849
    surprising. the only other place i can think of is toyota tech info, but that's 15 bucks. hopefully, someone here has it for you.
  5. gggGary
    gggGary gggGary
    79
    28
    Baraboo WI
    2023 Prius Prime
    XSE Premium
    As you said the power port fuse is under the dash and it's marked on the cover.
  6. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    #6 m.wynn, Apr 21, 2017
    Raytheeagle likes this.
  7. Colin
    Colin Junior Member
    33
    I'm sure I'm just not understanding things correctly but I just went outside and looked under the fuse cover under my hood and it's clearly labeled inside?
    Did I just not understand that correctly?
  8. bat4255
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Mine has no lable
  9. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    See if this helps...
    m.wynn, bisco and Raytheeagle like this.
  10. bat4255
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    It helps a lot,
    m.wynn likes this.
