2016 Prius V Two: What part is this?
Discussion in 'Prius v Main Forum' started by GhostFingersXP, Jul 22, 2023.
  1. GhostFingersXP
    GhostFingersXP Junior Member
    Louisville
    2016 Prius v wagon
    I’m new to this forum so apologies if this has already been identified.
    I have a 2016 Prius V Two that I bought used and while I was cleaning out the rear cargo area, I found this piece lying inside the spare tire area.
    Can someone please help me identify what this is and where it should be?
  2. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It looks like the screen for the battery cooling fan input that resides near the door on the passenger side of the rear seat.
    JeffD
    djasonw, Air_Boss and rjparker like this.
  3. GhostFingersXP
    Louisville
    2016 Prius v wagon
    Thanks! I checked the area you mentioned and could not locate any vents (pictures attached). I removed the panel but didn’t see anything that matched up.
  4. GhostFingersXP
    Louisville
    2016 Prius v wagon
    Mystery Solved! Thank you @jdenenberg for getting me in the ballpark.
    I took a closer look at the air intake setup for the battery and noticed the tube went underneath the carpet of the back passenger side seat. I removed the hose and voila! The mystery piece was the screen for the end that’s underneath the seat!
    I sifted through the maintenance records of the car from prior to me owning it and the dealership had done a service on the battery at some point but clearly didn’t do a complete put back together of everything they pulled out.
  5. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Man, glad you found this out. That is a really important component for the battery!!
    GhostFingersXP and Air_Boss like this.
