2016 rear hatch open sensor faulty?
Discussion in 'Gen 4 Prius Main Forum' started by HerbMPG, Jul 7, 2021.
  1. HerbMPG
    HerbMPG Junior Member
    30
    Decatur GA
    What device, sensor or momentary switch tells my Prius the hatch is open?
    Today I opened the rear hatch which, as always, unlocked the car. However, the car locked itself automatically the same way it does if you unlock but don’t open a door. I checked further and found Prius can be locked with key or sensors even when hatch is open. Also, hatch open light on dash does not light up.
    If I can find the switch or sensor, I can test or replace it.
  2. ChapmanF
    19,059
    Don't know about 2016, but in Gen 3 it is part of the hatch latch assembly.
  3. vilmaemery
    vilmaemery New Member
    Hartsville, SC
    2017 Aqua
    Limited AWD-e
    Thanks! This makes sense.
