2016 SAE free paper previews
Discussion in 'GM Hybrids and EVs' started by Jeff N, Apr 6, 2015.
  1. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The SAE has released free partial previews of some of the technical papers being published in conjunction with the annual SAE World Congress convention in April.
    Here's a list of the papers related to the 2016 Volt:
    GM 2016 Volt Overview
    The Next Generation “Voltec” Extended Range EV Propulsion System
    GM Volt Experimental HVAC
    Energy Efficiency Impact of Localized Cooling/Heating for Electric Vehicle
    GM Volt electric mileage statistics
    Chevrolet Volt Electric Utilization
    GM Volt 1.5L engine
    Development of the Combustion System for General Motors' High-Efficiency Range Extender Ecotec Small Gas Engine
    GM Volt power electronics
    Power Dense and Robust Traction Power Inverter for the Second-Generation Chevrolet Volt Extended-Range EV
    Trollbait likes this.
  2. Trollbait
    12,808
    "The addition of a high geometric CR and high-authority camshaft phasers for extended late intake valve closing (LIVC) operation has enabled improved low- and mid-load engine efficiency."
    Sounds like the ICE can go full Atkinson, and is more thermally efficient at high loads than the current 1.4L
    And, "Evaluation of one year of in-use operating data from first generation Chevrolet Volt Extended-Range Electric Vehicle (E-REV) retail customers determined trip initial Internal Combustion Engine (ICE) starts were reduced by 70% relative to conventional vehicles under the same driving conditions. These Volt drivers were able to travel 74% of their total miles in EV without requiring the ICE's support."
    So a little better than the two thirds figure usually used.
