2016 snout
Discussion in 'Prius v Main Forum' started by Ripcurrent, Jan 17, 2018.
  1. Ripcurrent
    Ripcurrent New Member
    Culver City, CA
    2016 Prius v wagon
    Does anyone know if the nose on the 2016 V is a purely functional decision for aerodynamic reasons?
  2. Prodigyplace
    12,712
    11,848
    Central Virginia
    I know the redesigned the car for 2015 to improve on the IIHS small overlap crash tests. My son has a 2015 Prius v.
    So the front was redesigned for more than just aerodynamics.
    I showed the 2016 to answer your question better.
  3. Prodigyplace
    12,712
    11,848
    Central Virginia
    Here is a quote about the improvement from IHS
    The Toyota Prius v, which also earns TOP SAFETY PICK+, saw even greater improvement. The midsize car had been one of the worst performers ever in the small overlap test. In 2012, the structure collapsed, and the dummy's head hit the instrument panel and ended up between the side curtain airbag and the door. Measures from the dummy showed left hip and lower leg injuries were very likely.
    After the structure was improved and the side curtain airbag was lengthened, the 2015 Prius v performed well all-around, with low levels of intrusion, good restraint performance and low injury measures.
    From 71 vehicles earn 2015 honors from IIHS
    52,849
    the snout that roared is purely an nightmare of toyota designers. it will grow on you. like a wart.;)
    Prodigyplace likes this.
  5. Prodigyplace
    12,712
    11,848
    Central Virginia
    Nissan is trying to compete for ugly...
    Nissan Xmotion
    RogerInColorado and bisco like this.
  6. bisco
    52,849
    starring roll in jurassic park.
    RogerInColorado and Prodigyplace like this.
  7. RogerInColorado
    RogerInColorado Junior Member
    16
    Boulder, CO USA
    2014 Prius v wagon
    They got a good jump on that goal with the Juke
