2016 Snow Performance
Discussion in 'Gen 4 Prius Main Forum' started by dropshot94, Jan 31, 2016.
  1. dropshot94
    dropshot94 Junior Member
    16
    Colorado Springs, CO
    We had a couple inches of snow last night (with about a foot to follow over the next two days). I'm happy to report that my 2016 4 with Nokian Hakkapeliitta R2s was able to get around our neighborhood without a problem. This includes a number of fairly steep hills. FWIW, I used Eco mode as I've seen suggested on a few threads. I do think the gentle acceleration prevented the necessity for traction control.
  2. Mendel Leisk
    42,271
    Sounds good. Do keep in mind, with the low ground clearance, if you get anywhere near a foot, especially if it's wet, even with the best snow tires you'll get stuck. Anything 8" or deeper is the limit, with wet snow.
    We've yet to get any appreciable snow this "winter", here. The roads look like they got hit with icing sugar one morning, that was the worst, lol.
  3. dropshot94
    16
    Mendel, thanks for the advice. Having spent five years in Calgary, I have no desire to be heroic in my winter driving.
  4. Mendel Leisk
    42,271
    My knowledge of snow is largely vicarious, thanks in part to global warming. :oops:
  5. dropshot94
    16
    And as of the end of today's snow, we have 18 inches. Tomorrow's commute should be quite the test.
  6. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Did you buy it with the snow plow option?
  7. dropshot94
    16
    Flying car option.
    iPhone ?
  8. dropshot94
    16
    The flying car worked!
    Seriously, though, the Gen 4 was quite competent in the snow. Very little traction control and no ABS activation. I drove in Eco as has been suggested in other threads and found it very good for moderating my acceleration. The route to work has a number of unavoidable hills and there were no problems even on the steepest.
    The temp was in the single digits for the morning commute, and even so, I managed 56.7 MPG (I suspect the slightly slower highway speeds helped).
    Overall, while not quite as rock solid as my previous AWD, I have no complaints.
  9. ExMachina08
    ExMachina08 Junior Member
    72
    27
    United States
    Out of curiosity, does the gen 4 kill power to protect the transaxel when you start spinning the tires?
  10. bisco
    52,784
    didn't the gen 4 get a traction switch?
  11. dropshot94
    16
    ExMachina08,
    Yes, it did briefly cut power a couple of times when I hit a slippery spot. A little jarring at first, but it wasn't too bad. FWIW, there's a traction control off button.
    bwilson4web likes this.
  12. Mendel Leisk
    42,271
    How deep was the snow on the roads then? Assume the plows had gone through?
  13. dropshot94
    16
    Yes, the plows had gone through. My neighborhood streets had three or four inches of packed snow. The main arteries were largely clear.
  14. Mendel Leisk
    42,271
    That's a good situation. What I hate is when the main roads are clear but the side streets are untouched, lol.
    Here I'm starting to contemplate taking the snow tires off; no snow so far, crocuses and daff's starting to come up.
    dropshot94 likes this.
  15. dropshot94
    16
    I'm lucky in that my neighbor has a truck with a plow blade.
  16. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    I'm glad to hear it, I was starting to think I was a little too quick to buy a FWD car. We are getting snow tomorrow and I'm a little nervous. I had a FWD car for about a year or two when I lived in Colorado, before I moved out here. Colorado is different though in that it doesn't get ice like we get here. I switched to an AWD as quick as I could though and I've driven an AWD for 11 years, I'm a little worried I don't know how to drive FWD in snow (and I didn't really when I moved to CO from CA but I winged it).
  17. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    If you drive slow enough you'll be okay. Just keep your distances from everyone and take turns SLOW. I wouldn't think it'd be any different than an AWD car other than the take off. What I do is coast to stops from WAY back and then I rarely have to take off from a stand still.
    Zojja likes this.
  18. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    Thanks, I figure most people don't have AWD so shouldn't be that difficult.
  19. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  20. Zojja
    Zojja Active Member
    275
    126
    DC area
    Four Touring
    that is just a crappy shoveling job. My other car was low to the ground so even being AWD, I knew I couldn't just climb over snow piles.
