2016 - Strut Nut - Technical Bulletin
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by TLCESQ, Oct 21, 2016.
  1. TLCESQ
    TLCESQ Member
    30
    31
    Recently developed obnoxious knocking sound inside vehicle. Could not determine cause. Spent 2 hours in dealer service; they couldn't identify cause of noise. Even dismantled entire back interior down to steel.
    Took it back for more investigation and they found a new Tech Bulletin identifying issue whetr the nuts securing the struts back out over time due to vibration, causing the struts to rattle. Seems to be an issue with many (200+ incidents so far). So, if your 2016 starts to rattle, this may be the cause. Quick fix with updated nuts and I'm back to a very quiet ride.
  2. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    I might have this. I've noticed an occasional clunk from the rear suspension. You wouldn't know the bulletin number would you?
  3. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    When you here symptoms of a bad disease, you swear you have it. I know I heard a clunk back there the other day.
    krmcg likes this.
  4. krmcg
    2,592
    2,393
    Whittier, CA
    Plus 1
  5. TLCESQ
    TLCESQ Member
    30
    31
    This wasn't a one-time or random sound. It happened quite frequently at low speeds, even on smooth surfaces. Only relief was at highway speeds.
    Unfortunately, do not know #. Check with dealer?
  6. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
  7. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Any one know if that nut is tightened from the cabin side, or under the car? I would like to take a look at mine.
  8. randomwalk101
    532
    271
    texas
  9. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Anyone find it yet? Take a picture?
    RCO likes this.
  10. Archimedes
    Archimedes Junior Member
    70
    45
    I typed in the number but nothing came up relating to Prius
  11. jasmine1979
    jasmine1979 New Member
    mabelvale
    Just had our first strut replaced at 15000 miles and now the second one at 23000...So far not very impressed with the 2016 prius.....
    Coast Cruiser and RCO like this.
  12. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Strut replaced, or the nut tightened?
  13. frankemtp1
    frankemtp1 Junior Member
    US
    Four Touring
    I had the same problem and it took two trips to figure it out. In order to hear the issue drive with windows closed and fan and radio off. The fix is easy and no issues after the bolt was properly torqued. I suspect a robot was having an off day.
    I should add that it is a 2016 Touring 4 that is by far the best car that I have ever owned .
    #13 frankemtp1, Nov 12, 2016
    RCO likes this.
  14. Ben Little
    Ben Little Junior Member
    PE, Canada
    Technology
    I've heard a clunk from the rear left side but only when I was driving on a road that was being repaved. Dont hear anything on paved roads or at highway speeds on bumpy roads. Got a 16000 service coming up, probably ask then, see how far I get.
  15. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Has anyone noticed this when braking only, I seem to have a ticking noise when braking? I agree, hard to hear unless it is very quiet, but annoying now that I have noticed this and happened to have the radio off
  16. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    My vehicle has the same rattling issue in the rear suspension. My 2016 is an early build and I've only had it for 2 months 3600 miles but I developed the rattling issue right away. I have an appt at my local Toyota next week and hope a (relatively) simple repair involving taking off all of the plastic and felt parts to get to loose bolts on the suspension struts will fix it.
  17. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    Noticed this on both of mine plus a little cold engine start up rattle.
  18. first_superior_prius
    76
    115
    Michigan
    I have noticed this... sounds like it is coming from both sides of the vehicle in the trunk, but from inside. That sound familiar to folks that have had the strut nuts tightened?
  19. altdel
    altdel Member
    70
    36
    Danville, CA
    On mine, it sounded like coming from the right side of the trunk inside the car. For me, it was very reproducible; you stand behind the car and push down on the right rear bumper in quick succession. You can hear the noise as a low-pitched clicking sound.
  20. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Some owners are having the entire struts replaced. They claim that is part of the Technical service bulletin.
    I called the parts department at the Toyota dealer, and he told me they were replacing the struts with the same struts! Same part number. Is Toyota re-installing the same bad struts? :ROFLMAO: Why does that not surprise me.
    I don't think the problem is with the struts, I think the issue is with the bad nuts that are coming loose. This new Prius sure is becoming very disappointing.
