2016 tires?
Discussion in 'Prius c Main Forum' started by priusmatty, May 26, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Hi all,
    Which tires do new 2016 Prius c come with? Does it depend on where they are purchased? And, are they all low rolling resistance (LRR) tires? On yours, do you have the stock tires, or did you change them?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Some C's will come with 195/50-16 inch tires and some will come with 175/65-15 inch tires. 16 inches will look cooler, but the 15 inch will get better MPG.
    Tire Rack claims the 195/50-16 and 175/65-15 OEM tire is the Bridgestone Turanza EL400-02. Usually Toyota uses multiple tires vendors.
  3. priusmatty
    304
    109
    Louisiana USA
    2020 Prius
    L Eco
    Thanks! Do you think that, whatever tires Toyota chooses for the c, will be LRR?
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    They usually are, but Tire Rack did not claim that tire was LRR, so we can hope they got the wrong tire.
    priusmatty likes this.
  5. chughes123
    chughes123 Junior Member
    66
    vancouver washington
    Toyo NanoEnergy 195/65/R15 A29 for the 2016 Prius '3'.
  6. viscositosis tribocessive
    28
    San Jose' CA
    2015 Prius c
    PriusC Three. 2015. 70k miles. OEM and replacement. Good Year Assurance Fuel Max. 175x65x15. PSI 49 lbs X 4. This tire has a high maximum tire pressure rating. Extra tire pressure and light driving style has always been the formula for improved fuel economy over all else. This has worked for me.
    roadrunner likes this.
