2016 Toyota Prius 3 Battery
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Chatterbox, Sep 3, 2016.
  1. Chatterbox
    Chatterbox New Member
    Livermore
    How long does the battery on the 2016 Toyota Prius last for?
    Thanks,
    Chatterbox
    apt49 likes this.
    52,871
    welcome! anywhere from a few days to 4 or 500,000 miles. in california, you have a 10 year, 150,000 mile warranty, whichever comes first.
    RCO likes this.
  3. eman08
    eman08 Active Member
    360
    192
    US
    Short answer. The life of the car. There is no specific time when your pack fails. Some fail prematurely before it's warranty is up due to defects, while some due to very very hot regions or not properly maintained. Many has lasted past 200k-300k and so on. Not every module is go to fail at once as it's usually a one or a few.
  4. Mendel Leisk
    42,358
    You're talking about the hybrid system battery?
  5. HVAC
    HVAC Member
    43
    44
    Seattle Area
    When I return from time traveling I will report.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The 2016 is a new generation, the forth, which uses a battery technology,LiION, unused in Priuses before 2012. So the oldest one is four years old.
    That makes predicting the future very hard. (the first three generations used almost the same technology called NiMH, which we have a good 19 years of history about.
    apt49 and RCO like this.
  7. HVAC
    HVAC Member
    43
    44
    Seattle Area
    Sorry Mendel. I meant that as a tongue in cheek reply to the original question about a new battery model that just started out. Lol
  8. snipercoder
    snipercoder Member
    76
    40
    CA
    Three Touring
    Make sure to park it in a garage or shade (in the summer) to keep the heat away from the battery pack. Heat tends to shorten battery life. Cabin temperature can get to 150F when parked in the sun. If you're in the Southwest, multiply this by 3 or 4 months out of the year and the battery will degrade over time. This is a new battery chemistry, so how much degradation over time is yet to be seen.
    RCO likes this.
  9. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    are there any battery monitoring apps, to map an individual cells status, voltage, temperature... health condition in other words.
  10. eman08
    360
    192
    US
    Far as I know, only the Toyota Tech Stream software will be the only software that will give you information about the HV battery. Apps like Torque is not designed for this complex electronics.
  11. Mendel Leisk
    42,358
    ScanGuage II, with an X-Gauge programmed in, will give you the battery temp.
    RCO likes this.
  12. alexgrigori
    163
    109
    Technology
    Hey, I want ICE temp too :), looks like it is also missing :(
    RCO likes this.
  13. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Scangague gives coolant temp,
    RCO and Mendel Leisk like this.
  14. alexgrigori
    163
    109
    Technology
    Thanks, I have downloaded the following free SW: Toyota_Techstream_Ver. 10.30.029
    RCO and eman08 like this.
  15. eman08
    360
    192
    US
    Requires a Mini VCI cable if you don't have one already. This is the same software that Toyota Techcians use at Toyota Dealerships.
    #15 eman08, Oct 12, 2016
    RCO likes this.
  16. alexgrigori
    163
    109
    Technology
    Apparently there are a big number of smart phone car diagnostic apps working via Bluetooth with OBD adapters like this from Amazon (the link does not work):
    Veepeak Mini Bluetooth OBD2 OBDII Scan Tool Scanner Adapter Automotive Check Engine Light Diagnostic Code Reader for Android Windows
    As you can see the investment is not big. The question reminds is does this apps and adapters comparable with Prius.
    My car is not yet arrived so I am unable to do this test.
    #16 alexgrigori, Oct 12, 2016
  17. eman08
    360
    192
    US
    Those are primarily designed for conventional non hybrid cars since many of them don't have the capability of complex hybrid system diagnostic unless you have a dealer level scanner. BlueDriver is what I recommend for a scan tool while Tech Stream is for the most comprehensive.
    RCO likes this.
  18. alexgrigori
    163
    109
    Technology
    Many thanks for your input. Have you ever try to connect this or similar devise to your Prius?
    Are there any hybrid components related info available?
