2016 Toyota Prius Hybrid
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Onew, Jun 19, 2024.
  1. Onew
    Onew New Member
    Burlington
    few days ago it said cooling oerformance of hybrid battery is low, visit dealer, but we did some searching and cleaned up the air vents or whatever it is called and now the msg disappeared!
    however today, it said that EV mode was not available this morning, and I wasn’t going too fast or anything either. I gave it some time, and now my display looks like this, with Trip A being messed up when it shouldnt be that much, my EV saying its at 100%..
    I called toyota, and they said to come in for a look but i wanted to see if this was something urgent I needed to worry about? because i wont be able to get it to a mechanic soon
  2. Tideland Prius
    16,681
    MID looks like a Prius c so I moved it to the Prius c section
    52,860
    unfortunately, you have to have the trouble codes read to determine if you should worry or not.
  4. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    Are you still getting the cooling performance message or just the “ev mode not available” message? The EV mode (button) is very limited and only activates with plenty of charge and if you’re going under 25 mph (40 km/h)
    Onew likes this.
  5. Onew
    Onew New Member
    Burlington
    no im not getting that msg now fortunately, but it says EV Mode deactivated excessive speed when i was going pretty slow.
    Maybe when the cooling system had an error, it heated up the overall system a bit? And thats why my EV mode is pretty rusty? Ahh
    #5 Onew, Jun 20, 2024
    Pri3C likes this.
  6. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    These are the symptoms of a battery that has lost its capacity.
    In the morning, after the night, several very weak modules in the battery were discharged lower than the others. The computer saw this and did not allow you to use EV mode. In a short time, these weak modules were charged to maximum and now EV mode is 100%.
    #6 Carall, Jun 20, 2024
    Onew likes this.
  7. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    Glad to hear you’re not getting the other message. The cooling fan vents can get clogged with dust and debris, so that was likely the first issue. Check it 2-3 times a year going forward and vacuum out if needed.
    As for the EV mode button, it’s a pretty useless function for anything beyond parking lot speeds, and even with a full battery being indicated it still might not want to turn on. As long as the hybrid battery is kicking on and off with normal driving (around 42mph / 67kph and under) you’re good to go.
