2016 Toyota Prius Technical & Package Information
Discussion in 'Gen 4 Prius Main Forum' started by Danny, Nov 18, 2015.
  1. Netcub
    Netcub Active Member
    344
    170
    Kentucky
    I want a 4T with a Moonroof! Maybe I'll have to get a 4 with packages and add 17' wheels and Fog lights.
    Tideland Prius likes this.
  2. Tideland Prius
    16,683
    Just for completeness (and for other readers), it's standard on 4T and 3T. All Touring models have TSS-P.
    Yes, you're just missing HUD and Moonroof.
    So, for anyone looking at a fully loaded car, you have two options:
    Four w/ ATP which includes HUD and moonroof.
    Four Touring which subs out the HUD/Moonroof for 17" Alloys, LED foglights, LED clearance lights, different plastic rear diffuser, blue contrast stitching on the SofTex seats and blue vent accents (other vent accents include turquoise and white depending on interior colour)
    MrBillTulsa likes this.
  3. MrBillTulsa
    MrBillTulsa Member
    174
    35
    In the hills west of Tulsa
    Yes, but after spending $1000 to $2000 ($3000?) on wheels of your choice, there is a host of other items offered on 4T over 4. Fog Lights, Clearance Lights, and Unique Rear Bumper Treatment come to mind. Any others?
    :eek:
  4. Netcub
    344
    170
    Kentucky
    So the 4T has the solid colored seats with blue stitching, and the 4 has the multi colored seats (cool gray/black) or tan/black?
    3 has fabric multi color and 4 has softex multi color...
  5. Tideland Prius
    16,683
    Well if you get black, it's a solid colour. It's only if you get Moonstone (Cool grey) or Harvest Beige (warm beige) that you will get the two-tone with the black. The same goes for the grey and beige cloth seats.
    The only thing special you get with the Touring (3 or 4) is the blue contrast stitching.
  6. MrBillTulsa
    MrBillTulsa Member
    174
    35
    Unique Rear Bumper Treatment is interesting to me because the new Scion sports car (model #?) has a muffler with a single input in the center (like the Prius) and has two fancy tailpipes, one left & one right, that may be made to fit through the bumper trim (I don't know - we shall see). Sounds like cool mod to me!
    :eek:
  7. Netcub
    344
    170
    Kentucky
    The "Unique Bumper" Treatment isn't all that unique... 2016-Toyota-Prius-r-LA-11-2015-II.png
  8. NuttyKat
    NuttyKat Member
    70
    49
    Eastern NC
    2014 Prius c
    Is the solar roof option gone?
  9. Netcub
    344
    170
    Kentucky
    YES
  10. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    And that's a bummer because now that the apex of the roof has been moved forward, the driver's compartment has a new level of "airiness" to it and I honestly don't see the moon roof being a big draw. And I'm a big fan of having a moon roof in my car.
    Netcub likes this.
  11. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Here are some things I'm noticing between the 2016 Gen 4 and the Gen 3:
    zor, Mendel Leisk and bisco like this.
  12. bwilson4web
    16,547
    Don't worry too much about the 12 V inverter and battery. There are several alternatives:
    • use inverter when car is stationary - a platform with a high-current, connector, raise the hood, plug-in, problem solved. My Echo configuration just used a pre-installed ground wire and I would just clamp in the +12V when needed. I kept the wrench with the inverter.
    • drop bottom pan and look for mounting locations - risk is to make sure it is 'water tight'. I would probably take the cover off the engine and see if it could fit there.
    • go with 201 V inverter - this provides the option of going to +3 kW and there should be a knock-out for the Japanese, rear-wheel drive inverter and motor. In effect, a Prius owner made, inverter that Toyota doesn't seem to want to sell us. This is the approach I would recommend. Better still, mount the high-power inverter under either one of the front seats.
    For good measure, make the 3d approach a future SEMA option.
    KrPtNk likes this.
  13. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    My current set up has the inverter stowed under the cargo floor in the hidden compartment. To use, I just set it on the rear cargo floor and plug it in. If I had to connect it to the battery under the hood, where does the inverter sit? Where when it's raining? If I mounted it somewhere up front, there's too much danger for water/road damage.
    For my current set up, the inverter sits inside the cargo area and I can close and lock the car while it's running, and the power cable exits under the closed hatch. It can rain/snow/sleet all it wants to.
    The high power inverter you mention needs to connect to the traction battery, something I don't wish to fool with. (I know that's what you did.) And the Japanese don't seem to want to sell us their version. I note that the Gen 4 has such an option, but not here in the US.
    I'm liking my Gen 3 better and better. :)
  14. bwilson4web
    16,547
    The hood rests on the platform holding the inverter. This provides enough protection from direct rain. Mist and fog are not a problem because the heat of operation evaporates it instantly.
    Don't fear the HV any more than the house wiring. (Damn it, I'm talking myself into buying a 2016 Prius for "BJ Associates".)
  15. Tideland Prius
    16,683
    @Danny might be able to shed some light on it but the solid "lightweight" tonneau cover looks to be fabric (I originally thought it was cardboard). If it's fabric, it might be able to fold up like a sunshade.
    Kramah313 likes this.
  16. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Going over specs quickly... almost 10% loss of rear leg room and decrease in headroom. Teenagers beware!
  17. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Yes I too was hoping for the e-Four AWD option. Interesting that the Consumer Reports first drive review mentions AWD is "being considered". I assume this means for a future model year.
    wjtracy likes this.
  18. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Teenagers - to the front! Wide hips in the rear please.
  19. Netcub
    344
    170
    Kentucky
    Thankfully the Cargo Area now holds 20% more Trolls than the outgoing model.
    bwilson4web and giora like this.
  20. bisco
    52,877
    maybe they added a jump point in the back.
    Terrell, Mendel Leisk and Netcub like this.
