2016 V ... Replace the water pump at 100k miles?
Discussion in 'Prius v Technical Discussion' started by curiousjosh, Mar 19, 2025.
  1. curiousjosh
    curiousjosh New Member
    2016 Prius v wagon
    I just got a used 2016 v... it's just hit 100k miles, and I was going to get the engine coolant replaced at the dealership.
    While I was doing this, should I get a new OEM water pump installed?
    I saw this was being suggested in some used prius models, wasn't sure if it applied to the 2016.
  2. Kentoooks
    Kentoooks New Member
    usa
    Limited AWD-e
    If you're already doing a coolant change at 100k, replacing the water pump isn't a bad idea — especially if it's the original one. It's not always necessary on a 2016, but preventative maintenance can save you trouble down the road. OEM is the way to go if you decide to do it.
  3. Mendel Leisk
    42,205
    100k is timely, for engine water pump, and thermostat. Not sure that the inverter water pump is any more durable. Best bet sitting down when dealership quotes. Any chance of DIY, say with Aisin WPT-190?
    ksyolsen and tony_2018 like this.
  4. tony_2018
    tony_2018 Member
    227
    68
    Water pump, thermostat, radiator hoses, inverter water pump, check to see if any inverter hoses are worn and replace
    ksyolsen likes this.
