2016 Volt vs 2010 Prius
Discussion in 'Chevrolet Volt' started by alfon, Jan 23, 2018.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Now here in Northwestern Oregon we are in the dead of winter. Temps range from upper 30's to low 50's, usually with rain and of course wet roads.
    Our 2010 Prius seem to take a bigger hit in MPG's in winter more so than our 2016 Volt Premier.
    Now the Volt when running just on gas averages about the same as our Prius in winter, and the Volt's mpg's gauge is right on the mark and the Prius is always over reading 3-4 MPG more than actual. Last fillup with the Prius, calculated was 48 MPG, which is about the same as our 2016 Volt when of course running the Volt just on gas. Now in summer the Volt will average close to 50 MPG just on the gas engine, while our Prius in Summer will average 55+ mpg calculated.
    I don't know if anyone else has both a Prius and Volt for comparison but this is what I have noticed during the winter. Also same gas used, Costco 87 octane reg. (10% Ethanol and winter blend gas as well which is not great for MPG's).
    52,858
    are they doing the same trips?
  3. Trollbait
    12,831
    Do you precondition the Volt while it is plugged in?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    @leeb18c owns both;).
    Not sure which year or model Volt, but it looked nice in white(y).
  5. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    Doesn't the volt use the engine to charge the battery mostly? Or does it also drive the car in most cases like in the Prius? Maybe the engine load is different and causes less drop off in winter.
  6. Trollbait
    12,831
    The larger battery means the Volt can turn the engine off more often, and for longer periods while in hybrid mode, once things have warmed up.
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Once charge depleted, it acts like a traditional hybrid with one big exception: the ICE will run at a set RPM to supply voltage similar to a portable gas generator. Depending on circumstances and need, there are different RPM levels it can select. It can be a little disconcerting to newbs when they apply more throttle but the sound stays the same. It's more intricate than that as there are variations and exceptions but that's the gist of it.
    Kramah313 likes this.
  8. Kramah313
    411
    326
    Dallas, TX
    This is what I thought. I wonder if that makes the differences in weather less pronounced.
  9. bisco
    52,858
    o/p says 'volt running just on gas'. is that even possible?
  10. Kramah313
    411
    326
    Dallas, TX
    I'm guessing he means not plugging in
  11. bisco
    52,858
    agreed, so there would be no ore help from the battery than the prius, i'm guessing.
  12. Prodigyplace
    12,715
    11,848
    Central Virginia
    I thought the Prime & PiP got better mpg in Hybrid mode than the comparable Liftbacks due to the larger traction battery so the engine did not need to run as frequently.
  13. bisco
    52,858
    if you don't plug in, idk if there's anymore juice. i always figured the pip did a little better due to li-on v nimh.
  14. Trollbait
    12,831
    It's more because of the larger capacity. The Prime does a little better than the Li-ion Prius.
    Prodigyplace and bisco like this.
  15. bisco
    52,858
    do you think larger capacity means more juice in hybrid mode?
    Prodigyplace likes this.
  16. Trollbait
    12,831
    It will allow more capture with regen.
  17. Prodigyplace
    12,715
    11,848
    Central Virginia
    Thank you for saying it better than I did.
  18. Trollbait
    12,831
    To add to that, a larger pack will help with regen even if the upper capacity limit while in hybrid mode is limited to that of the hybrid. Moving energy in and out of a battery generates heat. With a larger pack, there are more cells to spread that heat out among, or to put it another way, each individual cell heats up less in the larger pack for the same amount of energy added or removed. This lets the PHEV capture more energy during a braking event before heat generation is deemed too much.
  19. Prodigyplace
    12,715
    11,848
    Central Virginia
    Are they still "dividing" the pack for the Prime?
  20. Trollbait
    12,831
    I think owners have seen regen push the SOC past the "hybrid" level, but it mostly happens in cases like coasting down a mountain.
    The "divide" itself is just in the software. The Prime will use all of the cells in its pack while in hybrid mode. Doing otherwise is foolish since it would mean aging part of the pack faster than the rest.
