2016 Wheel Sizes / Bolt Pattern
Discussion in 'Gen 4 Prius Accessories and Modifications' started by eric1234, Jan 26, 2016.
  1. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
    I tried searching and couldn't find this, so I'll apologize in advance if this is already covered.
    I just put down a deposit on a 2016 Prius Three. And, I've gone online to search for winter tire/wheel packages, and the easy way (input year and model) isn't working. So my question is this: Did the wheel size / bolt pattern change from 2010-2015 to 2016? Or, are they the same? (Which would mean I could just shop for wheels for a 2010-2015 prius?
    PS anyone have any good source recommendations? TireRack is showing out of stock on their lower priced 15" wheels that are compatible with a 2010-2015 prius...
    #1 eric1234, Jan 26, 2016
  2. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Did you mean a 2016 Prius?
    In any case I am in the market for another set of wheels for Winter tires and hence I have the same question.
    I spoke with Tirerack back in December and they need to have a vehicle driving into their Indiana location to make measurements on before they list the compatible wheels on their website.
  3. eric1234
    392
    201
    Hamden, CT
    I did - thanks! I've corrected the original post. Thanks!
    I'll keep the thread posted on what I find.
  4. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    This would be really helpful information. Because if the bolt pattern is the same I can reuse my winter tires of the gen3 on the gen4 :) - assuming I am getting one ;)
  5. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    I believe the bolt size/pattern is the same. Not so sure about the offset though. Small changes might be ok. Best way currently to tell is to try a wheel from a GEn 3 on the Gen 4. Not the spare (if you have one), as that is different. Perhaps ken@japan will see this and let us know. He is usually first with this kind of info.
    You can measure the offset yourself if you have both wheels. Lay them flat on the level ground (floor) outside up. Measure through the bolt holes from the bottom of the hole to the floor. If they are both the same then no problem.
  6. eight08customs
    eight08customs Senior Member
    245
    583
    Hawaii
    The bolt pattern is the same 5x100
    We have already fitted 20x9 on the car in Japan
    Lucifer and Oversplode like this.
  7. eric1234
    392
    201
    Hamden, CT
    Wow - that's an extreme prius...
  8. eight08customs
    245
    583
    Hawaii
    Test fitted my old wheels from my Prius 30 .. wheel spec are the same fitment.
    19x9 Fronts +49 Rear +37
    Rears
    Fronts
  9. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    As I understand it there are three parameters used to properly fit a wheel to the vehicle: Bolt pattern, Offset, and Centerbore. It seems confirmed that the Bolt Pattern is the same as the Gen-3 Prius (5x100). What about the other two paramters?
  10. eight08customs
    245
    583
    Hawaii
    Its the same. my wheels fit the same on the new prius
    BLITZ XW50 likes this.
  11. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Thanks.
    What about the tire pressure monitoring system in the Gen-4. Will the Gen-3 TPMS work for the Gen-4? (looking to buy a compatible TPMS sensor, no re-use))
  12. eight08customs
    245
    583
    Hawaii
    not sure on the TPS but toyota will not make a TPS sensor for each car. many are the same part number. they have to re sync to the car though by the dealer
  13. eric1234
    392
    201
    Hamden, CT
    I just installed my snows that I ordered from Tire Rack using a "2015 Prius" as the basis -
  14. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    Sorry to revive a old thread but since I was searching for threads involving offsets this one came up. Yes, I used the search feature (y)
    When you were trying your current wheels on the 4th gen Prius did it fit even though you're gen 3 is wide body? Just wanted to clarify in case this post was made before your added the kit.
