2017 brake noise
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by mmbrenda, Sep 2, 2017.
  1. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    There is no click and no light.
    Depending on the degree of the incline, sometimes the car will pull away as if you had just let off the brakes with no resistance, but more steep inclines you can feel the brakes releasing. Maybe the lesser inclines are held by the transmission rather than the brakes?
    As already mentioned, its only for a few seconds. I haven't times how long it lasts.
    52,240
    anyone have the o/m detail?
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It doesn't beep. I'm not sure, but I don't think there's a light on the dash, I'll take a look next time I use it.
    RCO and bisco like this.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It's just listed under "Driving assist functions" a list of functions that operate automatically in certain driving conditions and is described as "helps to reduce the vehicle from rolling backwards when starting on a uphill".
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It doesn't beep, there's no light indication and it doesn't work of you're facing downhill.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    We finally get to see your Prius :)!
    Nice color choice BTW(y).
    RCO and Prodigyplace like this.
  7. bisco
    52,240
    so... it is not the source of op's concern?
    RCO and kithmo like this.
  8. mmbrenda
    mmbrenda New Member
    FL
    I'm not in any kind of hilly area honestly. Pretty flat Florida roads and no extra lights or anything from me. Also, I suppose my initial "super loud click" was a bit dramatic lol I guess it's really more of a creaking.
    I'm really new to this whole regen braking thing so I'll have to read up more on that to know more. In case that could be it as mentioned previously.
  9. bisco
    52,240
    have you tried cleaning rust off of the discs by putting it in neutral on a quiet road around 30 mph and slowly applying the brakes?
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    TBH, I can't say I've ever had a car with front disc brakes that didn't creak at low speed. I've always took it as normal for them to creak a little as the pads break contact, usually amplified by the suspension on McPherson struts.
    RCO likes this.
  11. Harters
    335
    427
    UK
    Excel
    Mine makes quite an audible click when I take the car out of the garage and apply lock, but I never hear it again during the day. I guess its everything settling overnight.
    RCO likes this.
  12. Just.Drive.It.
    Just.Drive.It. New Member
    27
    25
    Here, There, Everywhere. Driving my Prius!
    My Prius makes more noise than a washing machine full of marbles! All kinds of weird clicks & clunks. The brakes are the strangest part of the car. Every day is different. Some days they are very mushy, and other days they throw you into the dashboard! I can't figure this car out! So I quit trying. As long as this crazy machine gets me from point A to point B with 55 mpg, I'm good.
    I turn up the radio and I just drive it.:LOL:
    #32 Just.Drive.It., Sep 8, 2017
  13. Marcius
    Marcius Junior Member
    69
    So Cal
    Three Touring
    When braking at slow speeds my front brakes, maybe just the driver's side, makes a lite, but noticeable bop, bop, bop noise until I come to a complete stop. I tried braking in neutral, assuming it would isolate my pads/rotors, but the sound does not happen then. So, probably the regen braking is making the noise? Also, I noticed the steering wheel shaking when slowing on long hilly roads at high speed -- I've had that before on other cars, and it feels like the rotors are warped. I think I need one more test -- long high speed downhill in neutral.
  14. donroyledbetter
    donroyledbetter Junior Member
    Brakes make horrible clunking screeching sound at the moment before complete stop and on release of pedal.
    Any one here with the same problem? A solution?
    This is my first post to PriusChat.
    You can hear the noise on YouTube by searching: @toyotafrenirumorosiscricch2355
    The noise started shortly after 7/21 new car purchase and has continued for 20K since. Has been to the dealer EIGHT times: they checked, they inquired to Toyota, they lubricated, they changed discs and pads, they reprogrammed a couple times. no change. We have appealed to Toyota Europe several times, they refer us back to the dealer who does not seem to care and points the finger at Toyota. The last reply from Toyota Europe was a patronizing: "The noise is caused by friction".
    I was very happy with my first new 2010 Prius, this one has been a total disappointment. That Toyota PR about relaxing warranty is BS.
  15. Marcius
    69
    So Cal
    Three Touring
    We still have braking noise as I mentioned in an earlier post. I heard from a random mechanic on youtube (go ahead and make fun, but no one including the dealer has a solution) that the anti-squeal plates on the brakes are actually causing noise. (The plates don't sit right, or something.) They said to eliminate the plates, then the noise will go away. I haven't done this yet, but I'm considering it.
  16. coeurdelion
    coeurdelion New Member
    Portugal
    Luxury
    I also have some clac clac noises breaking sometimes for as long as I can remember on a 2017, I have no idea what it is but I assumed it was something due to the hybrid system, maybe regenerative.
